Might Buy This F250 Need Help
I have come across an:
2003 F250 Super Crew Cab Lariat 6.0L 118,000 I can get it through work for $8,800 plus tax and tags. Is this a good deal and is the truck going to hold up. I drove it and it seems in pretty good shape. I am going to have a friend that is a diesel mechanic check it out. What do you think? |
sounds good! good luck
X2.... Let Me Know If Ya Don't Want It!!! I'm Interested!!!!!!!!!
I work at carmax part time. Employee discount kicks ***. Should there be any motor problems or tranny problems I should be worried about. I have been reading about the 6.0's
definitely make sure the recalls have been done cuase 03 had a couple on the 6.0
Whats the best way to find out.
![]() The list is long!! The tranny in these trucks is pretty dang strong! The motor: Head Gaskets & Puking Coolant, Eating Coolant, WHITE SMOKE, ECM Programming, FICM Programming, Weak Head Studs, Hard Starting "Cold & Hot", The list goes on and on!! The Best thing that I can recommend for you to do is drive it straight to the nearest ford dealer and have them do a diagnostic scan and go through everything!! Spending a $100 Now could save you alot of headache & thousands of $$$$ down the road!!! GOOD LUCK!!! |
i dont know much about it but somethin called an OASIS report, it gives the history of the truck
Is there anyone out there that ccan run and oasis report for me.
You can get an oasis on the org here but you have to be a premium member
