best mod for the 7.3 - Ford Powerstroke Diesel Forum
post #1 of 34 Old 01-07-2009, 06:28 PM Thread Starter
spanky's Avatar
ok guys what the best mods for a 02 f 250 7.3?
spanky is offline
post #2 of 34 Old 01-07-2009, 06:29 PM
Nally7.3Powerstroke's Avatar
well by mod do you mean performance such as chip, turbo, injectors, and so on?
Nally7.3Powerstroke is offline
post #3 of 34 Old 01-07-2009, 06:33 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I think it depends on your wallet!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #4 of 34 Old 01-07-2009, 06:34 PM
Haha yea good point. If you mean performance I would go with a custom tune chip, lots of power.
post #5 of 34 Old 01-07-2009, 06:44 PM
OregonStroker's Avatar
ya man, I had a edge w juice and took everyones advice about the tony wildman and it DOMINATES the edge. simply put, a good bang for your buck would be a custom 6 position Tony Wildman chip. TS also does a good job. Look at stealth automotive or talk to Raul. He will hook you up.
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #6 of 34 Old 01-07-2009, 06:46 PM
smitty16s's Avatar
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
what they said chip that thing get some gauges and build the tranny if its an auto.
1999 F-250 Supercab 6spd 2WD
Custom tunes by Tony Wildman,
AFE stage 2 Intake, ZooDad Mod, 2 Guages, Grand Rock 5" Aussie Stacks, Train Horn Qssb Quick Spool WOP, ITP regulated Return, Boost Regulator, Pioneer avic d3 Coming Soon: Injectors,short throw shifter, southbend clutch
smitty16s is offline
post #7 of 34 Old 01-07-2009, 06:53 PM
strokerguy's Avatar
nothing like a tw 6 pos chip
99 f350 reg cab 4x4 zf6 speed stock for now
strokerguy is offline
post #8 of 34 Old 01-07-2009, 06:57 PM
TW Chip. turbo back exhaust, guages, and DIY intake. that will wake your truck up..... alot
2004 ext. cab long bed xlt.
ARP Studs
Black onyx Headgaskets
Sinister EGR Delete
5inch exhaust w/ 8inch Tip
S&B Intake
BD Convertor
Sct X3 w/ IDP Extreme Race
6.0_Strokin is offline
post #9 of 34 Old 01-07-2009, 07:01 PM
20stroker02's Avatar
Turbo back exhaust, I have a brand new MBRP SS with a tip that i'll sell ya( check out my post for more info ) you need airflow in and out with extra fuel of a chip
2011 F350 CC/SB Ultimate Lariat FX4, Black on Black
Leveled w/37" Nitto Trail Grappler
20" Badlands
USMC
20stroker02 is offline
post #10 of 34 Old 01-07-2009, 07:08 PM
if your on a budget like most of us. and you just got a 7.3. You should do the following until you can afford to go baller status. yank the muffler out put a piece of strait pipe in. look up the tymar filter and do it. also do the Zoodad, you can find that on here also. or type it into google. then look at doing the Fuel Plate Shim Mod. also known as FPR Mod. also found on here. these things will really wake up the 7.3 from how it is off the floor. then, when or if you can afford it, do the Tony Wildman chip.
dont brake.
