7.3 and 6.4 questions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-07-2014, 09:02 AM Thread Starter
I am in the market for a new truck. I have been looking at the 7.3 and 6.4. I have some questions pertaining to both.
The 6.4 first. I know there have been problems with them. I also know that really we only hear from owners when there are problems, not so much when the owners are happy. I am having trouble determining the majority, whether it is people with problems. I have also heard that there were less problems with the later models such as the '10 6.4. How reliable are the later model trucks. I live in Maryland, correct me if I'm wrong, but all truck 2008 and newer are subject to emissions and all emissions equipment must be as it was from the factory. I know the 6.4 is much better w/o all the emissions equipment but is there anyway i can get around this law or make it reliable with the emissions intact.
now for the 7.3. we all know how reliable the engine is. one concern is the vehicle that I'm upgrading from is a model year 1999, so i would be paying for a vehicle which is only a couple years newer. now as long as it will last i don't mind. I'm looking for something in the range of 75000 miles or so. knowing that it is older technology but how much of a towing capacity difference is there between say a 7.3 and 6.4.
any and all advice is helpful.. I'm sure some of these questions have been addressed before, so not to beat a dead horse but if there is a forum someone can direct me to that would also be much appreciated.
SOMDcRAB is offline
post #2 of 5 Old 06-07-2014, 09:57 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Welcome to the org
On the 7.3 good luck finding one with low mileage, pretty sure the max gcwr is gonna be 20k
On the 6.4 you could remove the emissions stuff in a manor that makes it easily able to be put back on, but to run without it you would need a tuner to make it run without the components, and that's where a lot of the money is too, either truck will pull anything but the 6.4 has a lot more power, I don't own a 6.4 however so not keen on reliability and endurance but I see them with high mileage everywhere
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 06-07-2014, 10:34 AM
alaskan155's Avatar
Quoted: 66 Post(s)
whats wrong with your 99? and 75k is going to be hard, i usually calculate 15k a year for mileage x 11 (2003) and 165k would be the national average for a 7.3, so finding one with 75k is going to be hard and expensive with no gains over your 99(probably be in the 20k range for a 4x4), you would be more in the positive in refreshing/rebuilding your 99 and putting a nice bts/john woods trans in it if its auto.
as for the 6.4, removing the emissions falls under federal law, so any state can enforce it, so even if you travel outside of Maryland and say go to another state, they could impound your truck if they chose to(worse case scenario)/fine you. (something to keep in mind)
as for bulletproofing the 6.4l it looks like the same as the 6.0, head-studs and egr, which there are upgrades that keep the egr intact, as for the cat/dpf delete, i didn't say to do it, but you can either gut it, or make it removable and reinstall it for your emissions test(i know a ton of people that do that). if you gut it(will need a tuner), then it will pass visual, but if your state does more than a opacity test it might fail emissions test.
but again this falls under federal law, so it is at your own risk and neither me nor this forum is at fault if you decide to break it.
this is one of the reasons i love the 7.3, the only emissions on it are the pcv on the passenger valve cover, and no cat, so as long as im not blow black smoke from it, i can pretty much do anything i want to it.
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #4 of 5 Old 06-07-2014, 11:09 AM Thread Starter
how easy might it be to remove the erg and dpf and then reinstall it for emissions. is it as simple as putting blocker plates and removing dpf and a tune, then taking blocker plates, installing dpf and putting stock tune back?
SOMDcRAB is offline
post #5 of 5 Old 06-07-2014, 07:45 PM
alaskan155's Avatar
Quoted: 66 Post(s)
cat/dpf
those show the 6.4l exhaust. found images on google
