Does any1 know?
Are these codes that my truck thowing a big deal?
P0475 Exhaust Pressure Control Valve P0603 Internal Control Module Keep Alive Memory (KAM) Error P0113 Intake Air Temperature Circuit High Input P0344 Camshaft Position Sensor A Circuit Intermittent (Bank 1 or Single Sensor) Thanks |
exhaust pressure is probably the EBPV...thats fine
KAM maby, im not familiar w. it intake is probably your senser not being in an air box if your have a DIY setup CPS is deff an easy fix, do it! |
The P0475 is your EBP sensor pull the tube and clean it. The P0603 is caused by your programmer. No worries there
The intake air temp code is because of your CAI The other one means change your CPS |
Thanks is there any way to explain where the EBP sensor tube is? Also anyway to help show where the CPS would be located? thanks
