Zf6 speed swap - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-27-2014, 02:24 PM Thread Starter
Zf6 speed swap
The automatic transmission is about to die in my 2000 F-250 7.3L. I want to swap for the zf6 speed. I'm not sure what I need to do it. Can anyone out there give me a list of everything I need for the whole swap, and can give a few numbers on the cost of the whole operation. Thank you.
Powerstrokeman25 is offline
post #2 of 4 Old 05-27-2014, 10:07 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
find a wrecked truck with a 6 speed.
this route should cost 1500-2500.
master/slave cylinder from ford. pre-bled.
pedal assembly.
auto pcm will work. but not the other way around if you swap to an auto.
you will need to modify the neutral safety switch so it starts with the manual.
you need a 6 sp trans and transfer case with the right input shaft (thats why its easier if you pull everything from a wrecked truck.
new cooler lines for the manual.
buy a whole clutch assembly that comes with a flywheel.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 4 Old 05-28-2014, 03:44 PM Thread Starter
I looked up everything i need for the swap and added all the numbers and came just shy of $2700, which sounds reasonable. I have the 4r100 automatic transmission, would I have to install a different transfer case and driveshafts, because not needing a different transfer case and driveshafts would save me $700.
post #4 of 4 Old 05-29-2014, 02:01 AM
JSchuricht's Avatar
The transfer case is mostly the same. You would need to change the input and if it's manual shift the linkage is a different length. Drive shafts are different, IIRC the rear is shorter and the front longer.
JSchuricht is offline
