First oil change on 7.3 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-25-2014, 08:38 AM Thread Starter
carlspeed's Avatar
Hi guys. Doing the first oil change on the truck since I've got it. I'm no noob to oil changes, but I am a noob to the diesel. 4 gallons of T5, and a oil filter? Is there anything special? I had read that it's probably a good idea to do the fuel filter too? Truck has about 240k on it.
EDIT: Had no idea the motorcraft fl-1995 was the cheapest filter, so I'll definitely be doing that. Autozone has a Duralast fuel filter, planning on doing that as well.
'01 F350 7.3l SRW CC 4x4 Lariat
carlspeed is offline
post #2 of 9 Old 05-29-2014, 01:54 AM
edaniels's Avatar
Well when it comes to oil I personally like using the delo that's comes in the blue jugs and a good motor craft filter but on the filter depending on how much it holds take a quart of oil and pour just about all of it in the filter this way the truck already has oil in the filter and don't have to work harder to get it there also on top of the filter there is a little rubber gasket dip your finger in the fresh new oil in the filter and rub it on the gasket doing this causes a good seal so that you won't have to worry about a loose filter and of course when putting it on there twist as tight as the filter WITH YOUR HANDS then do a half to almost full turn with the oil filter but with the fuel filter I change mine out about every third oil change.
edaniels is offline
post #3 of 9 Old 05-29-2014, 02:03 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Oem fuel filter please
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 9 Old 05-29-2014, 02:53 AM
I used motorcraft oil and fuel filter. Rotella oil. Dont forget to fill the oil filter with oil before installing!
mlp2435 is offline
post #5 of 9 Old 05-29-2014, 04:12 AM
hansel's Avatar
Quoted: 99 Post(s)
Stick with Motorcraft filter's, I use them for oil and fuel.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #6 of 9 Old 05-29-2014, 06:45 AM Thread Starter
carlspeed's Avatar
Thanks guys. I guess it's the same as an oil change on a regular gas engine after all. Where can I get the top part so I can use an OEM fuel filter next time? It had one of the filters on it that was connected to the cap. I changed it, but I'd like to do OEM next time. Also, there is a bunch of gunk in the bottom of where the filter goes. How can I get that out?
post #7 of 9 Old 05-31-2014, 04:47 PM
Quoted: 2 Post(s)
You should be able to find a fuel filter cover on eBay cheap enough.
If there's crap floating around in the bottom, the first thing you should try is draining the fuel bowl. There is (should be?) a yellow lever on the front corner of it that will drain fuel out onto the ground (usually it manages to clean the axle in the process, unless you've rerouted it). Throw something under there to catch the crud and drain the bowl, and it should get most of that out. If there's still grit, rinse it/wipe it out with a lint free cloth or something.
Or just get a turkey baster & suck the fuel and crud out. But try the drain valve first. You may need to run the engine to get enough pressure to blow it down if the drain tube is a bit clogged.
Syonyk is offline
post #8 of 9 Old 05-31-2014, 04:56 PM Thread Starter
carlspeed's Avatar
Drained fuel. Just a bit of crud in the bottom.
post #9 of 9 Old 05-31-2014, 06:27 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
brake clean, shop vac, turkey baster
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
