going to the sno and no block haeter - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-30-2008, 05:57 PM Thread Starter
FENKER's Avatar
going up on the seccond and dont have a block heater, and the truck is a cali truck so where it came from and where i live it never really gets below 35* but going up and was wondering what i should do, if anything?
1997 f250 HD ex cab sb with southbend 450hp singlemass clutch, 6" lift with 35"s, 3 1/2"down pipe with straight pipe, afe stage 2 intake, tw chip, ccv mod, 17* hpop, 120v idm,vegistroke system V3. (AKA electric fuel for diesel and veg side)
UPCOMMING MODS:diy fuel bowl delete,fass pump for diesel side, stage 2's, d66 turbo or modded h2e
no parking cone at stanford university
FENKER
FENKER is offline
post #2 of 11 Old 12-30-2008, 05:58 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
nah, as long as your glow plugs are good, you will be fine.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 11 Old 12-30-2008, 06:04 PM
AJF
AJF's Avatar
You don't need to do anything 35 degrees insnt really that cold
AJ
2001 F-250 Lariet
Ext. Short Bed 4x4
DP Tuner, JWVB, Cowl Induction Hood, 6637 Intake,
4'' MBRP Exhaust, WW, Dfuser Fooler, Mac Inc. HPO-X, CCV mod, no EBPV, DI up pipes, Bilstein schocks, Ranchhand Bumper
AJF is offline
post #4 of 11 Old 12-30-2008, 06:09 PM
AJF
AJF's Avatar
Just make sure batteries are ok along with glow plugs and glow plug relay too
AJ
2001 F-250 Lariet
Ext. Short Bed 4x4
AJF is offline
post #5 of 11 Old 12-30-2008, 06:13 PM
Mud-Nut's Avatar
Send a message via MSN to Mud-Nut
My block heater wasn't working for a little while, and I live in Northern Ontario... My truck would still fire up in -15*F weather without any problems.
2001 F250 (Extended Cab, Short Box)
7.3L,
, NV271, 5.5" Lift, 37" BFG Baja Military Tires, Recentered Powder Coated H1 Wheels, DIY Intake, 3.5" Exhaust, Autometer Gauges, '05 HD Headlights, and TW Tuned!
1979 F150 (Regular Cab, Short Box)
460 BBF w/ Nitrous, C6, NP203, 14B FF Locked, HP D60 w/ Spun Inner C's, 5.13 Gears, 39.5" Boggers, Built Bumpers, Warn M12000, Built Front Radius Arms, Built Rear Shackle Flip (in progress), and much more...
Mud-Nut is offline
post #6 of 11 Old 12-30-2008, 06:18 PM
powersmoker's Avatar
make sure you have the right antifreeze mix is all
powersmoker is offline
post #7 of 11 Old 12-30-2008, 06:36 PM
Send a message via AIM to yeehaw MN12
make sure their is a winter fuel in it or else you might experience some gelling issues but yea 35 degress is not too cold i have yet to plug my truck in just gotta glow it right and let it run a few minutes before i heard out anywhere
kyle, 96 f250, S&B intake, 3 inch DP, 4 inch exhaust, 4 inch stacks w/ rain caps, many exterior mods
yeehaw MN12 is offline
post #8 of 11 Old 12-30-2008, 07:40 PM Thread Starter
FENKER's Avatar
no thats the temp at my house im going up to the snow in tahoe
FENKER
FENKER is offline
post #9 of 11 Old 12-30-2008, 07:51 PM
03dieselman's Avatar
You should be fine as long as you put some fuel additive in that has anti-gelling properties. It will start fine without a block heater in average northern winter temps.
06' F250, 6.0L, Xl, 4x4, 3:73 Ls 4" Turbo Back,
12' F150, 4X4, 3:55 E Locker, Xlt, Super Cab, Ecoboost, Sct Tunes
94' Jeep ZJ, 4" Rough Country, 33's, And A Bunch Of Broken Parts.
10' Polaris Sportsman 850 Xp!
03' 6.0L Sold
96' 7.3L Sold
87' 6.9L Sold
03dieselman is offline
post #10 of 11 Old 12-31-2008, 05:48 AM
STANG302's Avatar
Find an anti gell aditive at a gas station or truck stop on your way up there. If you go with out make sure you don't go under 1/2 a tank with refilling. Just another way of preventing gelling. As far as starting don't worry about it. If its not below 0 you should be able to run the glow plugs once and she should fire up. If not cycle them a couple times till she does. And don't be suprised if it sounds like the truck is going to explode. Runs a little rough till it warms up. You can help that by going to 5w-40 or thiner oil. I haven't pluged my truck in for weeks and its been down to -16. Never had a problem starting.
04' F350 King Ranch
4' MBRP Turbo back
EGR valve delete spool
B&W Goosneck
STANG302 is offline
