VW TDI (ALH) Question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-21-2014, 04:55 PM Thread Starter
It's a 2000 Golf that I bought with 172,000 miles on it back in September. It now has 193,000 miles. I bought it from non car people and had all the non car people problems with it. It also had the original fuel filter on it. I've changed the fuel filter 3 times since and since the last time at 192,000 miles it has had a hard cold start after it sits for 8 hours or so. It seems to have lost its prime at the pump (these cars have no lift pump). I've checked my connections and the clear plastic fuel line has no air bubbles. I was wondering if anyone knew if there was an air bleed somewhere on the pump. Or is this something to do with the fuel filter. It's a Chinese WIX.
04 F-350 Single Wheel 4X4
05 Excursion
2000 VW Golf TDI (dead)
Joe Kelsch is offline
post #2 of 10 Old 05-21-2014, 05:33 PM
Quoted: 28 Post(s)
Did you replace the the o-ring on the thermostatic t on top of the filter? If the original filter was indeed on it it could have over worked the fuel pump and you could be sucking air from the seals. Do you see air bubbles in the fuel lines after the filter? Timing belt? Hammer mod? Have you checked out tdiclub yet???
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #3 of 10 Old 05-24-2014, 09:04 AM Thread Starter
I put new O-rings on that came with the filter. There's no air after the filter in the clear line. I'm hoping the pump isn't weeping and losing its prime. I can't find any wet spots so I can't confirm if it is.
I've posted this question on TDI.com. They don't seem to want to answer any questions that I have. I do the searches. This question has never really been answered so I thought I'd ask. I get more help from here and V8buick.com than there anyway.
05 Excursion
post #4 of 10 Old 05-24-2014, 10:19 AM
Quoted: 3 Post(s)
I remember a similar post on tdiclub where a guy added the bew lift pump to his fuel tank and solved his problems, ill see if i can find it if your interested.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 10 Old 05-24-2014, 12:07 PM Thread Starter
I would be interested in putting in a lift pump. It beats the $1000 or so I'd need to spend on a new injector pump. This car has 193,000 on it now. I don't want to spend a whole lotta money on something that may last only another 20 or 30k.
05 Excursion
post #6 of 10 Old 05-24-2014, 12:25 PM
Quoted: 3 Post(s)
ill see if i can find it, thats not alot of miles for it, alh and bew are known to last to like 500k, even with crappy maintenance alh are hard to kill
2000 DRW CC 7.3
post #7 of 10 Old 05-24-2014, 01:26 PM
Quoted: 3 Post(s)
ALH lift pump addition, how to? - TDIClub Forums
Here u go, scroll down to post 4
2000 DRW CC 7.3
post #8 of 10 Old 05-24-2014, 02:47 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Awesome thread even though I know it's because you are having issues. I have (well my wife has) a 2002 VW Beetle with the ALH and it's been a fun little car to wrench on. Thankfully, it hasn't given me too many issues, but I'm glad to know that there are other TDI guys over here.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 10 Old 05-25-2014, 04:55 PM Thread Starter
Thanks for the link.
My wife found this car 10 miles up the road (I live in a very rural area). It was owned by non car people (meaning it got worked on when a light turned on). It's an automatic and its only getting 43mpg right now. I want to delete the egr and fiddle around with some other stuff to get the mpg up. I have a hard time working on it because it never stops moving. 43 mpg is a whole lot better than the 19mpg my truck's getting and the 15 the excursion gets.
05 Excursion
post #10 of 10 Old 05-26-2014, 05:46 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Interesting. My wife is getting 45mpg in her Beetle and figured that's about as much as we could get. I know what you mean about the maintenance. Since we have owned it over the last year, I have:
1. Replaced the clutch and flywheel (Dual Mass Flywheel was toast) with a South Bend Stage 2 and Single Mass flywheel
2. Done the Crayola-ectomy to get rid of the crayon smell and replaced the factory sound deadening with Dynamat
3. Fixed the seat belt air bag issue
4. Upgraded the injector nozzles to Titan 520's
5. Malone Stage 2 tuning
6. Replaced all 4 glow plugs
Because we have annual emissions testing, I have to leave the EGR system alone. Keep us posted on your progress and maybe we can help you with ideas to squeeze out that last little bit of mileage. I know some folks are well over 50 mpg.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
