Which engine is the best (other than the 7.3) - Ford Powerstroke Diesel Forum
View Poll Results: Which is the better engine out of the newer 3?
6.0 10 43.48%
6.4 3 13.04%
6.7 10 43.48%
Voters: 23. You may not vote on this poll
post #1 of 3 Old 05-17-2014, 08:33 PM Thread Starter
Ramrod77's Avatar
So obviously the 7.3 was the best diesel Ford has ever put in their trucks however which engine is the best out of the newer 3? 6.0, 6.4, or 6.7? Just curious to see what the general consensus is.
Ramrod77 is offline
post #2 of 3 Old 05-20-2014, 04:27 AM
Wolfesscythe's Avatar
Quoted: 2 Post(s)
Votes for the 6.0's.... Seems there's some trolls about.
I keep hearing about how the 6.7 is Ford's new 7.3, so I'd go with that.
2001 6-Speed F250 SCLB - South Bend SFDD250-6 Dual Disc Clutch - 7.3 with DIY 6637 - Diamond Eye Turbo-back 4 inch straight - TS 6-Pos PHP Tunes - Billet X-Wheel - Foil Delete | 1988 5-Speed F250 SCLB - 7.3 IDI - Stock
Wolfesscythe is offline
post #3 of 3 Old 05-20-2014, 04:55 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
"Scorpion" for me.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
