2005 f-250 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-17-2014, 08:09 PM Thread Starter
Exclamation 2005 f-250
so a friend of mine has a 2005 f-250 that is chipped and has a edge tuner and when you turn the truck over(normally the tuner should come on). it doesn't went to the edge website to find the tuner but as this this truck was used it we don't know what model it is. we push the buttons on the tuner and nothing. is there any one who can help me and my friend out in figuring what is wrong with this. please email me your suggestions as to what is wrong. email is bear9417@gmail.com
countryboy_9420 is offline
post #2 of 8 Old 05-17-2014, 08:31 PM
john galt's Avatar
Quoted: 1096 Post(s)
just a thought but if you have a cable, attach the edge to your computer it should tell you model serial number and let you update it and that MIGHT fix your problem?
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #3 of 8 Old 05-17-2014, 08:36 PM
strokersixo's Avatar
Quoted: 32 Post(s)
Check that the obdii fuse is good, it's under the dash, I believe it's fuse 14, can you hook up the edge to your truck for example to see if it powers up?
Also why use edge tuner? It fools the pcm on the fly to get it to do what u want, not the best method. Lots of guys here use SCT tuners, it reflashes your pcm and tranny with a new tune, stock tune however is still stored on the SCT tuner if you ever need to go back.
--MAX--
strokersixo is offline
post #4 of 8 Old 05-18-2014, 02:39 PM Thread Starter
thank you both very much i will try that and i do not have the chord and the reason he is using the edge tuner is b/c it came with it when he bought it Friday evening.
post #5 of 8 Old 05-18-2014, 03:05 PM
Quoted: 32 Post(s)
Keep us updated. Also tell your friend to get rid of the edge tuner and grab a SCT x3 and I recommend drew at backroadperformance.com Street king tune is what I'm running and very happy with it. or Tony Wildman at www.totaldieselperformance.com they both write great custom tunes and are sharp, smooth shift and LOADS of power. There are lots of custom tune writers but these are the two I like.
I'll be buying extreme tune from Tony as soon as I get my truck back from getting studded next week.
--MAX--
post #6 of 8 Old 05-18-2014, 03:09 PM Thread Starter
will do i will mention it to him. and are you sure that it is fuse #14
post #7 of 8 Old 05-18-2014, 03:10 PM Thread Starter
and the tuner is mounted on the dash and it wont power up at all
post #8 of 8 Old 05-19-2014, 12:18 PM
Quoted: 32 Post(s)
I'm pretty sure it's fuse 14, but check the owners manual, I can't find the link to a owners manual online, but check that all of your fuses are good, under the dash and the fuse box under the hood.
Have you tried plugging in something else to the obdii reader, like a code scanner? To see if it powers up, if it does then it's your edge, if doesn't, fuse is blown.
--MAX--
