2000 7.3 no speedometer - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-16-2014, 03:34 PM Thread Starter
It have a 2000 f350 with the 7.3. The speedometer, odometer aren't working and abs light is on. I replaced the vss on the rear end and a speed sensor on the tranny.the scanner says it's a speed sensor. Any ideas?
Tcast09 is offline
post #2 of 3 Old 05-16-2014, 03:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Checked the fuses?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 05-16-2014, 03:58 PM Thread Starter
Yea I checked them. Could it be a wheel speed sensor in the hub?
Tcast09 is offline
