F250 Exhaust - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-16-2014, 11:41 AM Thread Starter
F250 Exhaust
2006 F250 4 door 6.0
I want to install a turbo-back exhaust and delete the cat if possible. Is there anything special I need to buy to delete the cat?
Tylerl90 is offline
post #2 of 3 Old 05-16-2014, 11:53 AM
johnnybgood's Avatar
Quoted: 79 Post(s)
Just the cat delete pipe. That's it.
johnnybgood is offline
The Following User Says Thank You to johnnybgood For This Useful Post:
Tylerl90 (05-16-2014)
post #3 of 3 Old 05-16-2014, 11:59 AM
When I installed my 4" turbo back exhaust system, it came with the pipes cut into sections that allow you some options.
If you want to keep your CAT, it has the adapters that connect a 4" pipe to a 3.5" pipe. If you decide to remove your CAT, it has the appropriate length section of pipe to install in place of your CAT. The same for the muffler.
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
