obd command - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-09-2014, 04:38 AM Thread Starter
Question obd command
Howdy, I've got a 04 f250 6.0. I'm trying to read the eot, via serial connect, the pid for this is 015C but what I get returned is "no data". I'm using an elm 327 connector, I can read quite a bit of data, coolant temp is no problem, rpm, speed, load etc.... but for some reason no oil temp. Any one have any suggestions? I've tried communicating via several softwares, OBD crazy seems to be the best of the prepackaged, and I've tried using a direct terminal, via Python - pyserial. So any suggestions (re comms, or if anyone has a reasonably simple, somewhat accurate method of determining oil temp), it would be greatly appreciated. Cheers.
fordisbest is offline
post #2 of 5 Old 05-09-2014, 04:44 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Which phone platform?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 5 Old 05-09-2014, 04:59 AM Thread Starter
phone platform
Not sure of that, its an elm 327 1.5a, running via windows 7 off pc, runnnig on a silicon lab CP 210x usb to uart bridge driver.
post #4 of 5 Old 05-09-2014, 07:06 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Download Forscan
Sent from AutoGuide.com App
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 5 Old 05-10-2014, 01:18 PM Thread Starter
Well thanks for the suggestion. I downloaded it, and I must admit is a very comprehensive program, but unfortunately, still no Eot. It did tell me, however, that aside from some problems I have with the backup sensors, which I knew and was grateful that don't work, (I hate the noise), that I may have a problem with an injector, or wiring around it. So while it still can't read my EOT, a big thanks for the rest of it. Cheers.
