Towed by a Dodge - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-14-2008, 04:58 PM Thread Starter
sldghamr's Avatar
Towed by a Dodge
yes my 96er broke down and ask my Dad to give a quick tow off the main road long enough to figure out what happened.
would crank, wouldn't start, no wait to start. i had seen this back in January 2008. i immediately figured it was the same fuse that went out back then. checked the fuse box under the hood and found one fuse burned out. grabbed the fuse for the trailer brakes, moved it over, fired up and then went to the local parts store to get another.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #2 of 7 Old 12-14-2008, 05:00 PM
cchase's Avatar
glad you got it fixed. does the 96 have a fuel bowl heater, may want to unplug or replace that, it can blow fuses and cause a no start
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #3 of 7 Old 12-14-2008, 05:16 PM Thread Starter
sldghamr's Avatar
that is the fuse that went it. per the owners manual, i have a fuel heater.
sldghamr is offline
post #4 of 7 Old 12-14-2008, 05:20 PM
cchase's Avatar
It is most likely shorting out. it happens alot. you can replace it or just unplug it, its on the fuel bowl.
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #5 of 7 Old 12-14-2008, 05:28 PM Thread Starter
sldghamr's Avatar
if it happens again, i will. is it really necessary to have the heater??
sldghamr is offline
post #6 of 7 Old 12-14-2008, 06:41 PM
Relytt58's Avatar
from what i know cali doent really get that cold so i wouldnt think you would need it. Mine went out here in wyoming and it got to the point to where i couldnt start in even on the block heater. It was -20 though
ROLLED as of september 4th 2010 sad day: Ford f350 superduty 7.3, chipped dont know what it is though, 4" exhaust to 5" mitres, K&N filter, 8.5" lift on 38X15.5X16.5 tires.
New project: 2000 Ford F350 lariat white 4 door short bed, big napa filter, TS 6 position from Tony Wildman, 4" exhaust, Protech cab guard 3 guage pillar. 8.5" lift, Built trans with triple disc converter GTP38R
Relytt58 is offline
post #7 of 7 Old 12-14-2008, 06:52 PM
cchase's Avatar
No, alot of people in the cold weather dont run the heater, I just found out one of our work trucks had it unpluged do a broken plug, and it gets really cold here
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
