Fiberglass tonneau cover with smoke stacks??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-11-2014, 06:48 PM Thread Starter
Does anyone have pictures of a fiberglass tonneau cover with smoke stacks? I've heard it has been done but I haven't found any pictures to prove it. I bought a used tonneau cover and I'm going to try it but thought I would see if anyone had seen it done.
James250 is offline
post #2 of 7 Old 04-11-2014, 06:54 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
I don't know that I've ever seen it done with a fiberglass cover. The holes would have to be a couple of pretty large ovals as to not hit the stacks when you open the cover.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #3 of 7 Old 04-11-2014, 07:01 PM Thread Starter
That's what I was figuring. Giving enough room when it opened, otherwise it will hit. I've seen it done with soft covers.
James250 is offline
post #4 of 7 Old 04-11-2014, 07:28 PM
Fantom's Avatar
Quoted: 12 Post(s)
Man, they'd have to be some pretty good sized holes. Also wondering how the gelcoat on the fiberglass would hold up to the heat.
John
100,000 Miles
Fantom is offline
post #5 of 7 Old 04-11-2014, 08:29 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
You could move the hinge after the stacks
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #6 of 7 Old 04-11-2014, 10:02 PM
Fantom's Avatar
Quoted: 12 Post(s)
The hinges mount to the rear cross rail
John
100,000 Miles
Fantom is offline
post #7 of 7 Old 04-12-2014, 04:12 AM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
I know. You would have to cut the cover right after the stacks and build a support for the hinge. So you would have a 16" or so solid mounted section with the hinge hooked to that then you have the rest go up and down. Ya it might be a lot of work but it would look awesome when finished. Then you could Finnish off the stacks with some chrome bezels to protect the cover and cover any heat damage.
01 f-250, Standard
sbluke55 is offline
