Cant find Parts.
On my 2000 My right window stopped working... So im pretty sure its my driver side window switch, but the problem is I cant seem to find any sites with a window switch. Can any1 point me in the right direction?
Does it not work from either switch? Could be the passenger switch too. Is the truck a standard cab or crew cab?
do google search for geniune ford parts that should get you some info
It is a Crew Cab. And I tried google, but cant seem to find a site that has them.
Have the same problem on my 03', ext cab. Dealer has already replaced drivers switch (while under warranty) worked for about a year, then intermittantly now finally dead (warranty expired now), can hear clicking while activating either switch, need to investigate further.
Thanks for looking for me! See I think its my right side becuase on my left side switch I can lower the window but not raise it and on my driver side it does nothing. I did notice while checking my driver side that if you took the right side window switch out you can not roll down ur driver window but you can raise it. I dont know if that gives any info or not.
window switches - Compare Prices and Buy window switches at Shopping.com Both switches have to be good in order for it to work properly. They have to complete the circuit to work. I would tend to think the passenger switch is bad instead of the drivers switch. Need to pull switches and check them with a meter to be sure. I don't know if I can get a wiring diagram but I will check. |
You are referring to the drivers side as the left side, correct?
I have a Chilton book with wire diagram, but im not sure how i'd test the switches how would i know if they are good?
