7.3 oil leak
Found some oil on top of the engine on the valley pan any ideas where it might be coming from.Valve covers look good.
check the piston on the EBPV on the pedestal. mine had a similar leak and it was oil going past the diaphgram in there.
psd
if you got oil in the valley.it should be coming from hpop gasket or fittings.the o-rings get old and leak.just get a rag and wipe where all the fittings are and then start truck and feel where the fitting is leaking.under pressure that oil will come out fast and may spray,watch eye
if its more in the back of valley,it your turbo O-rings? |
I had oil dripping from the dust shield on the tranny, looked like a rear main leak, however it was the HPOP lines coming out from the HPOP. One fitting was loose, just had to tighten it and was thankful thats all it needed. I had a lot of oil puddled in the front of the valley behind HPOP and under the fuel filter.
I think my truck is doing the same.Did you change EBPV or did you change the pedestal.
i gutted the EBPV and pulled the piston and diaphram out. threaded that hole and plugged it, so now the oil just cycles through that chamber. next time i pull the turbo i plan on swapping the pedestal for the non-EBPV.
Thanks for your help do you think I should by none EBPV or gutt mine.What do I do with the turbo end off the plunger and the plug that goes to the front of the pedestal the none EBPV pedestal dose not have one.
i got the same problem already changed the o-rings on the hpop.the one fitting towards the front of the engine started leaking again.i used a local auto parts o-ring,could there be a problem with my pump or just a cheap o-ring. 2001 f-350 no engine mods. any advise would be helpful. thanks
Did you get the leak fixed!
