Which to buy - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-27-2014, 04:27 AM Thread Starter
Which to buy
I am looking at buying a used diesel. I have heard bad stories about the 6.0 motors and I heard if you do a few things to them they will last forever. I have found a couple 6.0 that I like real we'll and I also found a 7.3. The 7.3 is a 2000 with 180000 miles for 12000. The 6.0 are around 150000 to 160000 miles and average around 13000 or 14000. Which would be the better purchase
Nick13 is offline
post #2 of 9 Old 03-27-2014, 05:07 AM
Heavy_GD's Avatar
Quoted: 1648 Post(s)
Feedback Score: 3 reviews
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #3 of 9 Old 03-27-2014, 06:40 PM
alaskan155's Avatar
Quoted: 65 Post(s)
Going to take 3 grand to get the 6.0 reliable I believe with head studs egr delete blue spring and etc. .but if it has those for 13 to 15k and is a 05 to 07 I would go with a 6.0 if not 7.3 all the way.
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #4 of 9 Old 03-27-2014, 07:39 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
6.0. Mine was problem free prior to egr delete and studs .
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
post #5 of 9 Old 03-28-2014, 04:40 AM Thread Starter
Alright guys thanks
Nick13 is offline
post #6 of 9 Old 03-28-2014, 07:19 AM
Mitch
thebierguy's Avatar
Quoted: 89 Post(s)
Just make sure you do your research on the 6.0 before you make a purchase. know what you are getting in to. I did my research and knew exactly what to look for, what to test, so I knew I was getting a truck that wasn't going to cause me problems right away. Read the stickies on the 6.0 page. Also, read the 7.3 stickies. I had both, and so far I like my 06 6.0 better than the 7.3. It rides smoother, the wife likes that it is a bit quieter in the cab, interior is nicer.
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #7 of 9 Old 03-28-2014, 09:48 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
depends what you need it for , a 6.0 deff wont last as long as a 7.3 , bullet proofing helps , but does not 100% guarantee it will be problem free , for 3 grand you could get some good mods to a 7.3 , instead of trying to make the 6.0 reliable
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 9 Old 03-29-2014, 03:46 PM Thread Starter
Alright what's mods do you recommend for the 7.3?
Nick13 is offline
post #9 of 9 Old 03-29-2014, 05:10 PM
Quoted: 13 Post(s)
hopefully more people chime in , or you can research it but im not big on mods
-Jeremy
Got A Few Rides...
