New member with exhaust questions. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-18-2014, 10:18 AM Thread Starter
02 7.3 F 250 CC SB with AFE Pro Dry S Stage 2 Ez Intake System and TS Performance Switchable 6 Position Chip. Difference in 4 and 5 inch turbo back exhaust is $66 so not much of a factor. Is there any down side to the 5 inch. Pull 4k boat. What are your thought and experiences?
Arizona 02 7.3 is offline
post #2 of 8 Old 03-18-2014, 04:35 PM
Quoted: 27 Post(s)
The only difference is sound. Have heard that the 5 inch has highway drone if straight piped. I have a 4 inch straight pipe turbo back and no problems with drone. Find someone with 5 inch and see if you like the sound.
Last edited by strokin-7.3; 03-18-2014 at 04:55 PM. Reason: corrected by 897.3alltheway
strokin-7.3 is offline
post #3 of 8 Old 03-18-2014, 04:45 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
5" it will only be a sound difference , dont think it will drop egt's anymore then a 4" would
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #4 of 8 Old 03-18-2014, 04:54 PM
Quoted: 27 Post(s)
I have been corrected. Thanks 897.3.
post #5 of 8 Old 03-18-2014, 05:51 PM
Quoted: 11 Post(s)
5" would drop egt's if you were making big HP , but for near stock its just gonna be a deeper tone
-Jeremy
Got A Few Rides...
post #6 of 8 Old 03-18-2014, 06:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
All these trucks drone at hwy speed it's just the tone, the 5" is deeper tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 8 Old 03-18-2014, 11:27 PM Thread Starter
With stock 3.5 inch going to 4 inch would be about 15% larger while 5 inch is 45%. Will be using a muffler in the system.
post #8 of 8 Old 03-22-2014, 06:04 AM
bljones2005's Avatar
I have the afe 4 inch straight pipe 3.5 down pipe. I think the 4 inch would be a pain not to have rubbing on mine. Tight fit. My 3.5 down pipe was good fit and 4 inch straight back sounds perfect. Nothing like hammerin it down and hearin it roar. Gotta be careful downtown turns so many heads esp the cops....lol. id like to hear a 5 inch though cause my 4 sounds pretty killer id say. Hardly any drone on mine but then again that type of stuff has never really bothered me cause I always have the radio up so loud haha!
2004 F-250 FX4 Lariet
Scangauge II
Maxtow gauges (fuel press,egt,boost)
High idle mod
Zoodad mod
CCV mod
Atlas 40 ficm tune
Sct X4 / Gearheads SRL tune
Blue spring upgrade
PMM bypass coolant filtration kit
PMM full egr delete
Diamond Eye 5" turbo back straight pipe
AFE stage 2 intake
Zerex ELC Cat-1 coolant
Rotella T6 oil
2 bottles of Rev-X
Diesel kleen/ Howes fuel treatment
Firestone rear helper springs/air bag suspension
Aux 50 gallon fuel tank/tool box in bed
bljones2005 is offline
