brake cleaner or carb cleaner? - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 12 Old 03-17-2014, 01:34 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
The story is im replacing the egr cooler and oil cooler on my truck right now and figured this might start a decent discussion. When cleaning the egr valve, people say to use carb cleaner, but when your cleaning the valley where the oil cooler sits people say to use brake cleaner. in my limited experience, brake cleaner leaves behind residue but carb cleaner doesn't. just curious why this is, or if they are basically the same thing and it doesnt matter.
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #2 of 12 Old 03-19-2014, 04:25 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Nothin????
6.0newb! is offline
post #3 of 12 Old 03-19-2014, 04:31 PM
sealeveloc's Avatar
Quoted: 19 Post(s)
I couldn't tell you the difference, but I typically just use what I have. loll
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #4 of 12 Old 03-19-2014, 07:38 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Haha same here!! Just wondering if there is some super secret thing that differentiates the two lol
6.0newb! is offline
post #5 of 12 Old 03-19-2014, 08:34 PM
john galt's Avatar
Quoted: 1311 Post(s)
some one once told me brake cleaner was stronger and a slightly broader spectrum of solvent where carb cleaner is more targeted at disolving grease.
not sure how much validity there is to that but i can tell you brake cleaner will remove wood stain and carb cleaner will not
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #6 of 12 Old 03-19-2014, 09:03 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Hahaha I guess that's good to know in case the wife wants to remodel the kitchen lol she probably wouldn't appreciate the smell though LOL
john galt likes this.
6.0newb! is offline
post #7 of 12 Old 03-20-2014, 05:17 AM
ZMANN's Avatar
Quoted: 1656 Post(s)
i believe the statement that brake cleaner has the potential ( there is more than one common chemical used depending on MFG) to be stronger like mentioned
i always fitt a glass and set my EGR valve in it just clear of the hole they warn you not to get any cleaner in leave it sit for a while and it works well I did use brake cleaner by accident once but that method didn't seem to compromise anything
We Miss you Ronnie
ZMANN is online now
post #8 of 12 Old 03-20-2014, 07:14 PM
supreme oppressor's Avatar
Other way around: brake cleaner should not leave any residue. It is also more damaging to plastics.
2006 F350 6.0 CrewCab Fx4 - Leveled & 35" Nitto's
2002 Subaru WRX
1983 Kawasaki GPz750 with the 810 big bore kit, parked.
supreme oppressor is offline
post #9 of 12 Old 03-21-2014, 08:14 AM
john galt's Avatar
but it will clean carpet fiber! Brake cleaner that is
I like mead
post #10 of 12 Old 03-21-2014, 08:22 AM
ZMANN's Avatar
how clean will it get them ? I wouldn't try that in a conspicuous area LOL
here is the 2 common types and they are nasty chemicals sometimes you see a residue but I don't think it will hurt the pads if the little bit is left on the rotor
Key Findings
Common spray brake cleaners contain highly toxic chemicals and probable carcinogens, such as dichloromethane (DCM, aka methylene chloride) and tetrachloroethylene (aka perchloroethylene or PERC).
Large manufacturers and formulators of automotive cleaning products provide non-chlorinated solvent alternatives, but these are often similarly toxic and dangerous to human health.
Many non-chlorinated brake cleaner formulations are highly flammable. Be sure to verify flammability characteristics of any new cleaner and re-evaluate job safety if products are changed to include flammable solvents.
We Miss you Ronnie
ZMANN is online now
