Tow mirrors glass - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-14-2014, 11:52 AM Thread Starter
Tow mirrors glass
Anyone know how to remove the glass from the tow mirrors on 08+ super duty?
VLX_fixation is offline
post #2 of 4 Old 03-14-2014, 12:15 PM
layson's Avatar
Quoted: 83 Post(s)
On my older mirrors, all you do is turn the glass all the way one direction. Stick your hand back there, there are little tabs that will pull right out. It doesn't sound good, they will make a little noise while the tabs pull out of the little motors. Then it slides right back in the same way.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 4 Old 03-14-2014, 12:18 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Yep, just get your finger back there (or an interior trim tool works well too) and pull firmly.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 4 Old 03-14-2014, 12:31 PM Thread Starter
That's what I've heard is just to pull. Eek that scares me. Lol k going for it!!
