Diesel Battery charging - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By kinnisoj
post #1 of 5 Old 03-12-2014, 03:47 PM Thread Starter
Hello all! I wanted recommendations on battery chargers that would be able to start my 2000 7.3 F250 if I was in a pinch. Over the winter, when I had not started it for a while, the batteries would not give the cranking power to start the motor. I also have a camper that takes 2 - 12V batteries that I would like to charge back to capacity and keep charged in the winter as well. Thanks for your recommendations. I also have a 3500W Generator I can plug my battery charger in if I needed the extra amps to turn over my truck if I was not at home to plug into garage outlet too. I have seen some chargers that say they can deliver that much amps if needed.
I have attached a few types of chargers I have been researching.
Battery Tender 022-0165-DL-WH 12-Volt 2-Bank Battery Management System
NOCO Genius G7200 12V/24V 7.2 Amp Smart Battery Charger and Maintainer
Schumacher SE-1052 50/10/2 Amp Manual Starter/Charger
Mrbrownstar is offline
post #2 of 5 Old 03-12-2014, 04:18 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ill tell you what I did for my camper. I went to Oreilly's (local auto parts store) and bought a simple solar battery charger. I believe its like 12"x12". I mounted it right on the front and it has worked like a champ for 3 years now.
I saw a very cool 20"x36" solar panel charger for I think it was $142 that would be awesome up on top of the camper.
I know my little panel has done a great job. the battery is always 100% and ready to go when we are.
Heavy_GD likes this.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 5 Old 03-12-2014, 04:21 PM
ZMANN's Avatar
Quoted: 1566 Post(s)
u don't need anything fancy or having "BANKS"
your batteries are tied together and are a 12 volt system a simple maintainer will work
if they were dead and you wanted to start you could have a higher amp alternative that would take a while or even the say 50 amp start option would work but you would still need to let it charge for a bit
We Miss you Ronnie
ZMANN is online now
post #4 of 5 Old 03-13-2014, 07:06 AM
AllGo'N'Show's Avatar
CTEK only way I would go, and keep both batteries just leave them hooked up together and it will charge both of them, you can get dual chargers but it isn't worth it. For you I would get the 7002 if you have other batteries you want to use or supply mode, for just normal tender/storage use the 4.3 is awesome.
'16 F450 6.7L Lariat Ult. .:. Tow-Rig
'08 F350 6.4L XL .:. Gone to a new home
Alradco .:. H&S+GH .:. RCD .:. PDR .:. S&B .:. aFe .:. Absolute .:. Fluidampr .:. Toyo .:. Black Rhino
Enjoy horrible service, sub-par quality and made in China product? Mishimoto is your one stop shop!
AllGo'N'Show is offline
post #5 of 5 Old 03-13-2014, 07:44 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Try harbor freight, they have some solar chargers that stick in your back window or windshield that keep the battery maintained if your truck is sitting. I know AGtires has one and he said he likes it.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
