What transmission fluid goes in a 1995 E4OD? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-04-2006, 06:35 AM Thread Starter
My manual is silent regarding trans fluid type, I was wondering what I should put in there when I change the fluid this week. Dextron II was suggested on another site, but I haven't seen Dextron II on the shelf in a LONG time! LOL....
Thanks,
Greg
_________________________
1995 F350 Crew
1992 BMW 850 V12 6-speed
1971 Ford Torino GT
1971 Ford Torino Wagon open road race project
Greg_Pettit is offline
post #2 of 13 Old 12-04-2006, 08:23 AM
mech2161's Avatar
Notes Fluid Type
Note: Ensure the correct automatic transmission fluid is used. Check the container verify the fluid is MERCON(r) approved. Transmission fluid requirements are indicated on the transmission dipstick handle. MERCON(r) ATF
Note: Use of fluid marked MERCON(r) V may cause internal damage.
Kevin
SPONSORED BY
Air Flow Systems
Terminator Engineering
DI Performance, South Bend Clutch
Discount Power Parts, Grand Rock
mech2161 is offline
post #3 of 13 Old 12-06-2006, 06:18 AM Thread Starter
mech2161,
Thanks for the intel. I wonder why my manual says nothing about trans service intervals or fluid types?
Greg
1995 F350 Crew
1971 Ford Torino GT
post #4 of 13 Old 12-06-2006, 06:24 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
your manual won't but your maintenace schedule book will.
I would take it to Ford for a fl;ush rather than just a change. It's much better to flush it out. Less than one C note.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #5 of 13 Old 12-06-2006, 03:25 PM Thread Starter
Appreciate the info, but..... There is no mention of the tranny fluid type in the maintenance manual either! Crazy.
Plus, I will never flush any automatic transmission. For the same reasons that I will never flush an engine.
Drain, replace filter, and refill should be plenty suffecient.
Greg
1995 F350 Crew
1971 Ford Torino GT
post #6 of 13 Old 12-06-2006, 03:33 PM
purduefarmboy460's Avatar
Send a message via AIM to purduefarmboy460
might be worth pullin the pan to clean off the mag at least, we've seen some pretty fuzzy ones, plus some chunks...
purduefarmboy460 is offline
post #7 of 13 Old 12-06-2006, 06:25 PM Thread Starter
Good idea, that would make it a little easier to get to the filter, too.....
1995 F350 Crew
1971 Ford Torino GT
post #8 of 13 Old 12-11-2006, 04:01 AM
Greg, dexron II, was replaced by dexron III. The type of fluid used is allmost always stamped into the dipstick. Dropping the pan and changeing the fluid every 25,000 miles is what I do..30 years in the trans business. Preston
ipz2222 is offline
post #9 of 13 Old 12-18-2006, 01:24 PM Thread Starter
Thanks, guys....
I changed the fluid and filter, and cleaned off the magnet. Man, there was a bunch of crud stuck on that thing!
I plan to change the fluid again in a couple thousand miles with the next oil change, as well, and then get on a regular trans fluid change regimen.
Also adding a large cooler soon.
Greg
1995 F350 Crew
1971 Ford Torino GT
post #10 of 13 Old 12-18-2006, 01:28 PM
cblackb's Avatar
Ok guys tell me if I used the right fluid. I put in Castrol "Dextron II / Mercon", it was in a black bottle. It said it would fulfill all the requirements for Ford Mercon specifications. I went to Autozone and couldn't find a bottle that just said "Mercon". It's probably ok but I would like to make sure. It's only been in there about 2000 miles.
2000 F-250 XLT PSD Auto Super Cab SB 4x4
Magnaflow 4" straight-piped into duals
Eclipse Sport Trucks Body and Interior Conversion
Tinted Glass
Zoodad Mod
Diablosport Chip (don't know HP)
Foil Delete Mod
DIY/6637 Intake Mod
Oilguard Bypass Oil Filtration System
CCV Mod
HPX Mod
Mag-Hytec Everything
BTS Valve Body
Cobra 29 LTD CB Radio
IAH Delete
cblackb is offline
