Newbie Owner Question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-09-2014, 01:22 PM Thread Starter
Seeing how the price of electricity is outrageous I would like some opinions on "plugging in".... I am not sure when and how long is really required....so would most people say below 32 degrees? and can I put it on a timer, so if I leave at work at 6:30 have it start heating at 4 or 5 or 5:30 ??? How long does it actually take for the full effect of the block heater to take effect???
thanks yall....
Buckeye_Joe is offline
post #2 of 5 Old 03-09-2014, 02:39 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I dont see what year of truck your asking about so Ill say up front Im answering for the 6.0 motor.
When I first got my truck anything at or under 32* it just plain did not like to start. It would but it would complain about it. Smoke,rompin around wouldnt idle smooth. Just not a happy truck.
Now since then I have gone to Rotella t6 from the dino oil. I run ARCHOIL fuel and oil treatment. I run anti-gel with a shot of 2-cycle oil in the fuel. My FICM is 100%. (old ficm voltage was around 39volts not its around 47.5-48v) It has a atlas 40 tune and 2 very good batt's and the big 3 upgrade.
Now my truck will start well past the below zeros and into the -teens without being plugged in. Now at that -teens temps ya she would rather be plugged in but it still started just fine.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 5 Old 03-09-2014, 05:18 PM
I'll answer for my 7.3, I've started it without being plugged in over night at 12 degrees F and she wasn't happy about it, romped around a bit and blew some white smoke and smoothed out. I plug mine in if it gets below about 35 just cuz I don't pay the electricity bill. But a 7.3s block heater is all full potential basically after about 2 hours so set your timer to that and she'll start much happier
Tow51Stang is offline
post #4 of 5 Old 03-09-2014, 05:20 PM Thread Starter
Thanks, guess that wouldn't really apply in my case...my info would be....1995 7.3 turbo, totally stock, new to me, but he has been using rotella 15-40, going to pick it up next weekend and dont remeber the exact oil he has been running, but he said it took a few cranks this AM, but it was about 15 degrees this morning....and he said he didnt plug it in, but prolly should of...
post #5 of 5 Old 03-09-2014, 05:21 PM Thread Starter
Thanks, my previous reply was being typed as you answered, looks like a good place to start...will do that and see how she does....
