Turbo surging and low boost. Powermax 6.0 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-07-2014, 09:13 PM Thread Starter
THEE RAT's Avatar
So I have a powermax turbo. And it is used. Just out it on. Was told was just rebuilt. So put it on and truck sounds sick and then I go for a drive. Only seeing 19 pounds and truck is surging while on the pedal.
What could it be? Could me VGT solenoid be bad? I just left the one that came with it on it. Still have my old one.
So frustrating after spending a few hours to instal. Now I have no truck lol
SOLD - 02 F350 CC LB DRW 6 speed 2wd
SOLD - 01 F350 CC LB 12inch lift on 24's and 38's
SOLD - E99 CC DRW 2wd 6 speed
TRADED IN THANK GOD! - 2005 DODGE 2500 CC SB
CURRENT-2005 CC DRW 2wd!
THEE RAT is offline
post #2 of 5 Old 03-07-2014, 11:09 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Check your hose going to your map sensor. It is very common to have a cut in the hose after install of turbo this will definitely effect the amount boost the charger will build. Do you have custom tuning for the pmax? I'm pretty sure you have to have a custom tune in order to run properly. Do you have a monitor if so can you monitor vgt? Maybe someone can chime in with a more definitive answer.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 5 Old 03-08-2014, 09:28 AM Thread Starter
THEE RAT's Avatar
I will check that. Also gonna change the noid and see what happens.
After the my old turbo going back on.
THEE RAT is offline
post #4 of 5 Old 03-08-2014, 03:36 PM Thread Starter
THEE RAT's Avatar
Changed the VGT selnoid and she's good thanks guys.
THEE RAT is offline
post #5 of 5 Old 03-08-2014, 03:39 PM
Awesome. I'm glad it was a quick and easy fix.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
