Can rotella elc and ultra elc mix?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-06-2014, 02:09 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Alright so the story goes that about 2 months ago I had to replace my water pump on my 06 6.0 so I did with a bpd unit. I also flushed and refilled with rotella elc. Well here we are today and I need to replace my egr cooler. When it was running at idle it would smoke white and it smelled sweet. It didn't leak till I turned the truck off then it would drop about a gallon on the floor. I can find the rotella ultra elc, and the regular rotella elc. My question is, can I drain the rotella elc that is in there right now and fill with ultra elc and not have any issues? Or should I just stick with the regular rotella elc until I want to do a flush again? Thanks
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #2 of 3 Old 03-06-2014, 02:30 PM
FORD4LIFE
powerstrokeculver's Avatar
Quoted: 2 Post(s)
Just do a good flush with some distilled water. Get all the old stuff out anyways. The ultra, according to shell has better properties to it. Why run the risk of mixing them. Would you mix your 15w40 with 10w30 because that's what you have on hand? Keep all the coolant the same. Not saying you can't do it, but that's what I would do.
Work Horse
2006 F250 FX4
6'' Lift Donahoe Racing
Toyo ATII's 35x12.5R18 on Moto Metel Black
BPD Engine Oil Cooler
BPD FICM 53V
K&N CAI
4" Straight Pipe
XDP Coolant Filter Kit
Blue Spring mod
SCT Tuned by DP-Tuning
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
155cc or 175cc Injectors
Stage 1 or 2 Turbo
BPD Water Pump
powerstrokeculver is offline
post #3 of 3 Old 03-06-2014, 03:16 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Well see normally I'd agree but I'm having a hard time convincing myself to run the truck when I know it was burning coolant, can't be blowing head gaskets right now lol
6.0newb! is offline
