Front Locker cons? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-24-2014, 02:14 PM Thread Starter
Front Locker cons?
I'm regearing to 4.30s and a grizzly locker in rear. Should I go ahead and put one in front or not? What are the cons?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #2 of 3 Old 02-24-2014, 02:16 PM
700xxmaniac's Avatar
Snow + locked front end = two hands on wheel with white knuckles
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #3 of 3 Old 02-24-2014, 02:19 PM
layson's Avatar
Quoted: 80 Post(s)
Worst part about a locker in the front, is if you loose all traction in the rear and all your weight is in the front. Say one wheel has some real nice traction but the other doesn't. Then all the power of your truck is now going through the one front wheel. Then it goes boom.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
