Repairing starter-96-7.3 Diesel - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-18-2014, 03:28 PM Thread Starter
Location: Central coast cal...Halfway between LA and Sanfran..
Renewing the brushes-I've noticed there are no screws holding the brushes to the shell or to ground--Is there an easy way to install them? I can silver solder them or use brass rod-I've ordered them from Rock -maybe they have connectors-There was sure a lot of crud inside after 150,000 miles=Thanks, Tom
macjunkyard is offline
post #2 of 2 Old 02-23-2014, 08:13 PM Thread Starter
Repairing Starter-96-7.3 diesel
I've cleaned it -sanded the armature and replaced the brushes now it work well-no more starting problems-But connecting the brushes is a big problem-I soldered them to the old brush ends-looks bad but works-I think you need a spot welder to do the job correctly--Tom
