Trapped in Chiberia! Cold starting PROBLEMS!!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-12-2014, 08:52 AM Thread Starter
I have a 2000 Excursion, 7.3 with 360,000 miles. Running a Superchips Flash Paq with the 70 hp. program installed.
Engine has a hard time starting in this cold weather, especially when in lower teens or below.
So far, I have changed the fuel filter, replaced the glow plug control module and the glow plugs.
I do use a fuel additive according to the directions, including increasing the amount when below 5 degrees.
I have cycled the glow plugs 3-4 times before trying to start.
The engine turns over (using Rotella full synthetic oil) but will not fire.
When it does, it sounds like it is firing off of compression only, instead of glow plug assisted.
Plugging in the block heater for at least an hour does help and allows the engine to start easier and sooner.
It will run rough for a moment and then smooth out.
After warming up, it runs fine, no strange exhaust (black or white) smoke.
It will also restart fine.
After sitting in cold for some hours, problem repeats.
I have tried fueling at different stations and problem follows.
There are no codes present.
Also, (maybe related ?) the engine experiences a "reverse surge". When the temp gauge comes up to the last of the white, the engine will drop 2-300 RPM and then return to normal. It will continue to do this until it reaches normal operating temperature. This was a head scratcher to the guy at Ford.
bluecrop is offline
post #2 of 6 Old 02-12-2014, 09:14 AM
jesilvas's Avatar
Quoted: 3 Post(s)
How long do you let the GPs cycle for? Till the WTS light goes out or the full 90 seconds?
How fast does it turn over?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 02-12-2014, 09:32 AM Thread Starter
I wait for the WTS to go out, and have cycled it up to 3 times as well.
Does not decrease the time to start.
Have cranked as much as 20 seconds without ignition.
It turns over fine and tries to fire but is very slow to actually start the engine.
bluecrop is offline
post #4 of 6 Old 02-12-2014, 10:44 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Try waiting 90 seconds after ignition on, because the GPs keep going for that long, or so.
Turns over fine but is slow to start? What does that mean? It turns over fast or turns over slow?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 6 Old 02-12-2014, 12:20 PM Thread Starter
The starter operates normally, albeit a bit harder because of the cold.
Real fear of burning it up from cranking it too long.
You can crank the starter to the point of the oil pressure coming up.
Engine tries to fire but will not. At this point, I plug the heater in and wait.
Other times, it will eventually start, sounding like a diesel industrial engine starting... Ka lakka lakka lakka.... shake rattle and roll, then ignition becomes steady and even.
bluecrop is offline
post #6 of 6 Old 02-12-2014, 01:36 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Only thing I could think of now is high pressure oil; wonder what the readings are.
4R100, 2wd
330,000 + miles
jesilvas is offline
