Exhaust Help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-15-2014, 09:10 AM Thread Starter
FastEddie885's Avatar
Exhaust Help
Hey everyone. Im looking to install the mbrp S6212 turbo back straight pipe system on my 2005 6.0. I have to deal with emissions every 2 years. is it possible to keep my old exhaust system and re-install it before smog testing? I know the dp is a different size and the easiest way to remove the stock one is to cut it. so im not quite sure what the easiest thing to do here is.
Any suggestions on the best route to go are greatly appreciated.
FastEddie885 is offline
post #2 of 2 Old 01-15-2014, 02:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Keep the cat and muffler (if the muffler is required) and make a slip joint where you can just remove and install as necessary for your emissions requirements
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
Tags
emissions , exhaust 6.0 , mbrp , smog , straight pipe
