Best rust preventative? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-15-2014, 08:22 AM Thread Starter
xxxjagsfanxxx's Avatar
Send a message via AIM to xxxjagsfanxxx
Hey guys just looking for some input. Just purchased a 2008 f350. Truck came up from Florida and has no rust. Unfortunately being from ohio I know it doesn't take long for the wonderful road salt to eat these trucks away. I've heard plenty o remedies over the years from people spraying undercoating. To soaking the underside with used oil every year. Just wondering what you guys have used or have had good luck with.
Sent from AutoGuide.com App
[COLOR="Red"][SIZE="2"]2002 F-350 ext. cab long bed 4x4
4 inch turbo back exaust with 6 inch miter cut stacks
isspro guages(boost and pyro)
S&B intake
boost fooler
TW 6 position chip
bd diesel turbo timer
8 inch lift
38x14.5x17 goodyear wrangler MT/R's
xxxjagsfanxxx is offline
post #2 of 11 Old 01-20-2014, 03:00 PM
The thing about rubberized undercoating is that it can allow moisture to get trapped between the rubber and the metal causing rust to go undetected. Its a real problem on vintage cars when you find 30 year old sound deadener used for rust preventative, because under that stuff evil lurks.
I have always liked the wax based stuff, it blocks oxygen and therefore can prevent rust. The thing about that stuff is it needs clean metal to adhere too. But, with a bug sprayer with a modified nozzle you can fog the inside of a door or rocker panel.
Fastback is offline
post #3 of 11 Old 01-20-2014, 03:10 PM
new7.3strokin's Avatar
I didn't know that about the rubberized undercoating. Subscribed to see what else comes up here
2001 F-250 lariat 4X4 - sold
2006 F-350 Lariat FX4 CCSB -
ARP Studs
Edge Insight CTS W/ EGT
MBRP 5'' turbo straight
S&B Air Intake
EGR delete
Ficmrepair.com Rebuild
PHP Atlas 40
Blue Spring
XDP Coolant Filter
Riffraff Boot Kit / Metal Pipe
Sinister Diesel intake elbow
2010 tailgate w/step
Harley Headlights
Plenty more to come........
HTML Code:
new7.3strokin is offline
post #4 of 11 Old 01-20-2014, 03:22 PM
ZWilson07's Avatar
Are you just looking for something easy to spray on real quick like rubber coating or something to go real in depth on like POR 15 or Eastwood?
  • 1990 F250 RCLB 7.3 IDI 4x4 ZF5. 45,000 original miles and factory original as can be.
  • 2006 Dodge 3500 QCLB DRW 5.9 CR G56.
  • Vehicles for days!
Will never buy anything from IPR and Sinister! List still growing
ZWilson07 is offline
post #5 of 11 Old 01-21-2014, 03:02 PM
midnite rider's Avatar
Quoted: 285 Post(s)
i put cheap trany fluid in a sprayer and spray all cracks and crevices i can every 6 months. trany fluid will get into places oil can`t lol
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 11 Old 01-21-2014, 03:05 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
Fluid film works really well
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #7 of 11 Old 01-25-2014, 02:20 PM
I've have yet to buy it, but a product call Krown came highly recommended from a local car collector. It's available in aerosol cans. Easy to spray into doors, cab corners etc.
You'll have to google it, it's a Canadian product. They have stations to have your vehicle done up north. The product is available here.
I'll be ordering some in the next week or two.
Derailed is offline
post #8 of 11 Old 01-26-2014, 07:00 AM
2nd for Fluid Film.
WOODYBC is offline
post #9 of 11 Old 02-07-2014, 05:49 AM Thread Starter
Just lookin for any type of preventative. Just seeing what you guys think works best pros/cons of different options. I'm probably leaving towards some type of oil base that I can spray. I've even seen people pull plugs on the doors and fill them with oil to prevent the dreaded ford "door rot".
S&B intake
boost fooler
TW 6 position chip
8 inch lift
post #10 of 11 Old 02-07-2014, 06:04 AM
Quoted: 2 Post(s)
Another vote for fluid film. Buy the kit and save the gouging they do for aerosol cans. I went with the upgraded spray gun, and extended flexible wand, and it really makes getting into the doors easy. I used about 3/4 gallon on mine if your curious. Extended cab long bed.
Fluid Film Undercoating
oilfieldtrash15 is offline
