Washing Top of Engine Off - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-09-2014, 08:31 AM Thread Starter
I need to clean my 7.3 Power stroke engine off. I will use awesome first to clean it, then rinse it off at the car wash. Will it hurt any sensors? Thank you for any assistance. Robert Todd
robertmtodd is offline
post #2 of 13 Old 01-09-2014, 08:51 AM
I usually mist the engine bay then spray simple green cleaner and let it sit and degrease then lightly mist it off. When dry I use tire foam on all the plastic/rubber to make it purdy. I have not used the 'Awesome' cleaner you mentioned. But I have not had any sensor issues with my method.
TxOutlaw is offline
post #3 of 13 Old 01-09-2014, 09:45 AM
Snake's Avatar
Quoted: 46 Post(s)
Hopefully you're putting the cleaner on at the car wash and not driving there with it on your engine.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #4 of 13 Old 01-09-2014, 10:28 AM
CNYWhiteDually's Avatar
spray simple green on heavy let sit for 5 minutes or so then power was off with wide fan spray. repeat untill all clean
CNYWhiteDually is offline
post #5 of 13 Old 01-09-2014, 10:56 AM
Rodslinger's B1TCH
I've used gunk engine degreaser and a pressure washer miltiple times on mine. I take the air filter out, stuff a rag in the intake tube and douche generously. I don't think any of the sensors or wiring are affected by water.
Then I take it for a long drive so it dries up quick.
steve604 is offline
post #6 of 13 Old 01-09-2014, 11:47 AM
whoa
'03 CCSB
6637
4" Lift
35" Duratracs
...More to come as money allows!
gentimmy is offline
post #7 of 13 Old 01-09-2014, 12:32 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I wouldn't wash a hot engine but that's your risk.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 13 Old 01-12-2014, 12:18 PM
jwsland's Avatar
I've put the power washer in the engine bay a few times. Down in the cracks and crevices. Truck wasn't hot. Used a backpack blower to blow any excess water off when I was done. Started it up right and let it get hot to burn the rest off.
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #9 of 13 Old 01-12-2014, 02:26 PM
Quoted: 2 Post(s)
Depends on what you feel comfortable doing. I won't lie, every vehicle I've owned, I've washed the engine at the car wash with the engine running, and standing on the front bumper blasting it with high pressure. I've had a lot of people tell me I've been lucky to never crack a block or damage anything. Keep in mind this is on relatively leak free engines and oem air intakes, no exposed air filters.
Now my 7.3, I have attempted to clean the engine a few times but the oil/gunk is caked on heavily. I'll probably end up spending a day taking stuff off and cleaning everything with scrub brushes and degreaser. (OReilly's Foamy Engine Degreaser is awesome for this kind of work).
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #10 of 13 Old 01-12-2014, 02:59 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Was every vehicle ones with limited electronics on them?
4R100, 2wd
330,000 + miles
jesilvas is offline
