Connecting batteries together in a pinch? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-08-2014, 05:06 AM Thread Starter
I had a buddy tell me that if you try to start your diesel and it's turning slow that you can use a jumper cable to connect the 2 batteries and sometimes it's enough to turn the truck over, kind of like jumping but not as effective.
Is this true or does it help?
Dave
lexinator02 is offline
post #2 of 5 Old 01-08-2014, 05:11 AM
ynpmoose's Avatar
Quoted: 7 Post(s)
I believe the batteries are already hooked together in parallel, so his suggestion makes no change electrically.
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #3 of 5 Old 01-08-2014, 07:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
^^^ this, the logic does not compute unless you have a bad connection or bad wires
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 01-13-2014, 10:50 PM
codyd5051's Avatar
Lol. They are already linked in parallel. Won't help at all. If it won't start you may require a jump and or new batteries/alternator.
2000 CCSB F350 7.3, Homemade BOF, Rebuilt trans w/ Trans Go Shift Kit and "HD" TC, In line trans filtration, Tru-Cool Max, Rotella 5W40, 4'' Exhaust, K&N intake (unfortunately), Ranch Hand Legend. 240k miles. Cooper M+S tires.
codyd5051 is offline
post #5 of 5 Old 01-14-2014, 08:35 PM
Like said, the batteries are already wired together in parallel. I believe your buddy is referring to using jumper cables to connect them in series, which would give you 24 volts, rather than 12, and would likely fry all of your electronics, including your trucks computer system. DO NOT TRY THIS AT HOME!!!!
2008 Ford F-250 6.4l Powerstroke, crew cab, 4x4
2013 Jeep Wrangler JK Unlimited, 2.5" lift
1978 Jeep CJ-7, 304 V8, 3 speed manual, 4" lift, 33's
Foulplay is offline
