Deisel Swap into old ford pickup! - Ford Powerstroke Diesel Forum
post #1 of 26 Old 01-06-2014, 09:29 PM Thread Starter
I have a 53 ford f100 pickup, I've been thinking about doing a full diesel swap for some time now. What do you guys think? is it even possible? i've never done anything like this, but was thinking maybe a 7.3, manual tranny.
huscroft is offline
post #2 of 26 Old 01-06-2014, 09:50 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Its been done. Guy had to widen the entire body 7 inches I think? thats a lot of motor designed for a small truck
Trucks and parts............
kanuck15 is offline
post #3 of 26 Old 01-06-2014, 10:18 PM
RACERX's Avatar
The 7.3 is wide and the Cummings is long. There is a 63 dodge with a Cummings 6.7 the firewall had to be moved into the cab to make room for the engine.
RACERX is offline
post #4 of 26 Old 01-06-2014, 11:05 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I wouldn't think you would need to widen the body 7 Inches. That is so much in terms of engine compartment space. Maybe the firewall was moved 7 inches for the intercooler and radiator. The 7.3 powerstroke is 34"L x 32"W x 36"H. Just fyi a 6.0 is bigger....
Powerstroke Dimensions
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 26 Old 01-06-2014, 11:10 PM
kanuck15's Avatar
Quoted: 10 Post(s)
I wish I could remember where the guy was from and where I saw it. Its been in diesel power I believe. I know for a fact he had to widen the body to make it fit. There was a lot of sheet metal work done
kanuck15 is offline
post #6 of 26 Old 01-07-2014, 12:15 PM Thread Starter
Thanks for the measurements! ill measure my engine compartment to see! You think the 7.3 would be a good motor for it? or would there be something with smaller dimensions.. Im not sure if i could widen the whole body for it.
huscroft is offline
post #7 of 26 Old 01-07-2014, 12:24 PM
Quoted: 8 Post(s)
I've seen 7.3 powerstroke in a mustang.... It was only widened at the strut towers which you know isn't your problem in a 53 F100
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #8 of 26 Old 01-07-2014, 12:25 PM
kanuck15's Avatar
Quoted: 10 Post(s)
Do you want it to just be cool? if so do a 4bt and it will fit right in there. Anything more and you will be into some modifications length and width wise
To further up my earlier statements I found the truck I was talking about being widened but its a 40s style trucks. Which is more narrow I believe
kanuck15 is offline
post #9 of 26 Old 01-07-2014, 12:27 PM
Quoted: 8 Post(s)
I have a 428 non CJ in my 67 F100 and according to my research the FE motors are 6" narrower than a 7.3 Powerstroke. Seems. Like 3" more on each side is doable without major sheet metal fabrication. Might have to rework the inner fenders but for sure
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 26 Old 01-07-2014, 12:37 PM
daddyusmaximus's Avatar
Quoted: 12 Post(s)
+1 on the 4bt.
99 F-250 Super Duty, 4X4, CCSB.
AKA: The Liberty Wagon.
daddyusmaximus is offline
