Need help making a decision 7.3 vs 6.0 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-05-2014, 10:06 PM Thread Starter
I am pursuing another diesel truck and am looking at two. One is a 1999 f250 xlt 4x4 out of state (I'm in michigan) so it's rust free. The other is a 2004 f350 6.0 diesel xlt 4x4 michigan truck but nearly rust free. Both have equal miles and are same in price. I've owned 7.3s and know how reliable they are. I know the 7.3s average 15-16mpg but the gauge in the 6.0 reads an average of 10.5mpg. The report says the 6.0 had an egr valve replaced in 2006. Now my question is should I buy the older truck that I know is reliable or buy the 6.0 and take a gamble on the engine and hope the fuel economy improves? Thanks in advance.
Hca1197 is offline
post #2 of 11 Old 01-05-2014, 11:13 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
It's a matter of preference. The torque shift behind the 6.0 is a much better trans.
I like the newer interior of my 05.
If you have a scanguage or something (i have the torque App for my Android) check the oil and coolant temps on the 6.0 after it warms up. 65mph on flat ground, the difference should be less than 15*. Check the FICM voltage with key on and during cranking, when running engine cold and warm. Voltage should not be below about 47.5 at any time
As far as the 7.3 is concerned, does it run? Lol I'll leave the quirks to someone else
Sent from a phone that makes calls too!
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #3 of 11 Old 01-06-2014, 06:03 AM
broncomitch's Avatar
For sure a matter of preference.
They all have there problems.
Before I bought a 6.0 It would need all the normal problems fixed and had proof of such..
I love my 7.3 and I been having problems with it sense I bought it (1999 with 235k and was a work truck) only little stupid problems, but the dang thing just rocks!
The 05-07 truck is better in every way apart from the motor...
So what I'm doing is slowly upgrading my 99 with all the good stuff of the 05-07...apart from the trans
Don't think there is a way to make that trans work behind the 7.3
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #4 of 11 Old 01-06-2014, 06:12 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
When I first got my 05 it wasnt getting much better mpg's than. After the ficm and other some other goodies were fixed, I now get around 13.8. Thats around town,not too much freeway and alot of hills.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 11 Old 01-06-2014, 08:53 AM Thread Starter
It's a hard decision. I know and trust the 7.3s but the 6.0 is five years newer so the truck has a newer interior and what not. The other thing I cannot decide between is the 6.0 being and f350 while the other is a 250. Anymore help would be appreciated.
Hca1197 is offline
post #6 of 11 Old 01-06-2014, 12:15 PM
Its a no brainer for me. I own two 7.3s and needed a third truck so I ended up buying a RAM 5500 with the 6.7 Cummins cause I dont trust the newer Powerstrokes. My uncle has been a diesel mech and has had more issues with the 6.0 engine than any others. I dont know about yall but I need my truck running me down the road vice leaving me stranded somewhere.
One of my 7.3s is a 97 FSuperduty. I hate that truck so much I love it now. Im in the process of pulling the tranny for a rebuild, along with rebuilding the entire fuel system, new turbo with up pipes. I dont much mind cause I know what truck I have when I am done sinking my cash into it. Not much for looks and the interior sucks, but hey its a work truck, not a family run around town truck. My other 7.3 is a 95 F250 with 408,000 on the OD and its about to make another trip to Ga from NY pulling a 7200 lbs skidsteer behind it. Interior dont look much better than the FSuperduty but again what a truck.
I would go with the out of state rust free 250.
BEEMAC is offline
post #7 of 11 Old 01-06-2014, 12:27 PM
HighHP's Avatar
Im a HD mechanic and I work for Cummins, and I just bought a brand new 6.7 F350, so whats that tell ya?
OP, personally id go for the 6.0 in your situation. Delete it and never look back, my brother, also an HD mechanic owns a 05 6.0 and he loves that truck, my dads got an 01 7.3, still a good truck, just aint making near the power of the 6.0 and no creature comforts...
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #8 of 11 Old 01-06-2014, 12:57 PM
It tells me you dont like Dodge trucks.
If you were to put 1.00 housing on stock turbo with stage 1 injectors in an old 7.3 wouldn't you produce the same power to the rear wheels without an innercooler as you would with the stock 6.0 which has an inner cooler, variable goemetry turbo and inner cooler?
Cant replace displacement.
How do you like your 6.7 Ford?
I love my 6.7 Cummins.
BEEMAC is offline
post #9 of 11 Old 01-06-2014, 01:18 PM
HighHP's Avatar
So far no complaints with the truck yet. I find it more comfortable then my 11 5500 service truck. Dont get me wrong, cummins makes a good engine, its ram that ruins it, my service truck body is falling apart around a pretty bulletproof engine for the most part, with only 40k miles on the odo. I had a hard time choosing between ford and cummins, ford just felt more powerful stock.
HighHP is offline
post #10 of 11 Old 01-06-2014, 05:51 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
only bad thing about the dodge is the truck falls apart around the motor.....the motor is the only thing that keeps up , as far as the 6.0 OP , even after you delete it and bullet proof it , they still have problems , not as simple as "its bulletproofed it runs forever"
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
