6.0 - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-05-2014, 01:07 PM Thread Starter
So my mechanic that works on my 05 6.0 is having trouble figuring out what is wrong with it... the truck will fire on the third or fourth time of cranking when cold around (20-30 degrees) and wont run right until its warm then runs perfectly fine could anybody help me out with what causes this and what i need to do to fix it.
Thanks...
PowerstrokeCraig is offline
post #2 of 16 Old 01-05-2014, 01:21 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
First off welcome to the site!
Do you happen to have any type of a monitor on your truck? (Edge,scanguage,livewire...etc.?)
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 16 Old 01-05-2014, 01:41 PM
luke7.3's Avatar
Quoted: 24 Post(s)
First thing I would do is 8 new glowplugs and a relay... especially if youve tried ether starting it
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #4 of 16 Old 01-05-2014, 03:10 PM
muddy650's Avatar
Check FICM voltage. Search that and you will see what it is supposed to be at when cranking
2004 F250 CC SB
SCT Xcal2 SPD+ Lonney Wild Track
ARP Studs
PHP FICM Tuner
2003 Turbo
Coolant Filter
EGR Delete
4" Magnaflow
Airaid Intake
Zoodad
Blue Spring
6.4 Banjo's
CAT EC-1
Custom Camo Seat covers
muddy650 is offline
post #5 of 16 Old 01-05-2014, 03:12 PM Thread Starter
Nope and okay
post #6 of 16 Old 01-05-2014, 04:31 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
You gotta get a monitor. Right now your truck cannot communicate with you.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 16 Old 01-05-2014, 04:58 PM Thread Starter
I have a sct x3 if that helps??
post #8 of 16 Old 01-05-2014, 05:03 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
that's for tunes. You gotta get a monitor. basically a small computer that plugs into your obdII port under your steering wheel and displays your settings on your truck and can also read trouble codes.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 16 Old 01-05-2014, 05:29 PM Thread Starter
How much?? And what brand do you recommend?
post #10 of 16 Old 01-05-2014, 05:36 PM
gotta_gofast's Avatar
Quoted: 62 Post(s)
Don't ever do this to a 6.0L powerstroke
Does the mechanic have IDS? 9/10 times this software will point him to the problem.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
