Driver side floor wet (2004 F-350) - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-21-2013, 11:32 AM Thread Starter
I have a 2004 F-350 Crew Cab and noticed the floor is wet on the drivers side after driving in rain. I have heard the sealer at the pinch weld eventually fails...any insights?
Thanks
r
Eric
Bartch46 is offline
post #2 of 7 Old 12-21-2013, 12:02 PM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
I would start by checking
1. inner fender
2. firewall plugs
3. under dash over column (for possible windshield leak)
4. Lift carpet and check for holes in floorboard.
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #3 of 7 Old 12-21-2013, 12:35 PM Thread Starter
Thanks. I checked all of your suggestions...the only thing that seemed abnormal was the floor plug (smaller of the 2) was loose in the hole. I gooped some silicone on it and reinstalled...will go find new plugs as it was pretty weathered.
r
Eric
Bartch46 is offline
post #4 of 7 Old 12-21-2013, 05:55 PM
95and05's Avatar
Also... how high is the floor wet? Higher in one area? Do you have a mechanical floor shifter for the transfer case or tranny?
94 IDI
95and05 is offline
post #5 of 7 Old 12-21-2013, 07:28 PM Thread Starter
The wettest area is under where the floor mat hook is, which generally above the loose floor plug. Its not wet under the pedals or along the kick panel. I do have a floor shifter for the transfer case, but it doesn't seem damp around there.
r
Eric
Bartch46 is offline
post #6 of 7 Old 12-22-2013, 11:36 AM
95and05's Avatar
Probably a simple fix then.
Fix plug, dry thoroughly, drive in rain again to check.
Hope that's it. Good luck..
94 IDI
95and05 is offline
post #7 of 7 Old 12-22-2013, 01:45 PM Thread Starter
Thanks for the tips.
r
Eric
Bartch46 is offline
