Need help from the experts! 6.0 or 7.3? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-18-2013, 07:36 PM Thread Starter
Ok guys I need some help on a truck purchase. I need to purchase an F550 stake body for my business and have found a few trucks that would suit me in my price range. I'm familiar with diesel trucks and have 5 of them in my fleet now, none of them powerstrokes. Closest thing I have is a 93 7.3 in a F450 truck which has always been a great truck, just has gotten old. Here's what I've found. First truck is an 2001 F550 with an automatic trans with 165 k miles. Truck is from the south and looks to be maintained well but has no service records as the guy purchased it to resell it. The second truck is a 2006 F550 with under 60 k and has a manual transmission. The guy purchased this truck for his business about 3 years ago and put less than 1000 miles on it in the 3 years he's owned it. Guess he thought he was going to need it but never really used it. The truck came from Texas and he has no prior service records. The truck does look like it's been maintained well also. Both these trucks are within a thousand dollars in price of each other. I'm kind of torn on what to do. The newer truck definitely does look nicer although I'd rather have an automatic. I'm not afraid to trow some money at the 6.0 to get the bugs out of it but not sure I want to dump 6 K into it for heads, studs and all the other problems they have. Does the truck have little enough miles to where it won't have the problems if I delete the egr and do an oil cooler on it now, it may not give me problems? Both trucks are stock and would remain stock if I purchase them. I generally keep my trucks for ten years or longer as this truck will probably be driven less thank 10k miles per year. What do you guys suggest?
giannid is offline
post #2 of 4 Old 12-21-2013, 09:54 AM
Joel's Avatar
Quoted: 10 Post(s)
For the intended purpose I would lean towards the 7.3
I'm not at all biased against the 6.0 either. If the truck in question had a different intended use my answer might be different.
But for a work truck the 7.3 will get you there every day without the need for excessive maintenance and monitoring.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 4 Old 12-21-2013, 10:05 AM
7.3workacholic's Avatar
I agree ^^^ 7.3 and work belong in the same sentence. 6.0 are good with right things done to them, but since this is for a business, reliability is an issue, 7.3 is the way to go, they just keep going.
1997 F250 7.3 E4OD Centurion XLT 2wd, afe prodry s intake, diamond eye down pipe dump, tonys tunes, fpr shim, swamps idm, de-stickered and molded, smoked headlights,heavy duty rear suspension, Gearvendors, 2in level, 18in xd hoss on 35in terra grapplers, 8x8 steel rear bumper, in the process of black on whiting her
7.3workacholic is offline
post #4 of 4 Old 12-21-2013, 01:38 PM
njmudrat's Avatar
Quoted: 7 Post(s)
2005 f350 Lariat,,Stock for now--Television, the internet, ipods, all influenced by POS trashy celebrities. The people that try to help raise kids in a positive way Teachers and Cops are now the sworn enemy.
njmudrat is offline
