First Time Buyer - 6.0L - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-17-2013, 05:33 PM Thread Starter
This is my first post here so I apologize if this is out of place.
A Ford dealer near me has a 2004 F250 Lariat on the lot and is asking $10,755. The 6.0L has 168,004 miles on it. Today the dealer sent me the warranty history on the truck which is dated between 2003 - 2006. There are several entries referring to a rough idle and/or misfire which the dealer techs attempted to address with the assistance of Ford Engineers. Over time the logs show the dealer replaced the EGR system, injectors #6 and #7, IPC sensor, IPR Valve, ICP Connector, engine looms and new PCM.
Since the logs end in 2006 I have no idea what other issues this engine has encountered. That being said, I know the 6.0L has had its problems. I've tried to do my homework and learn as much as I can but I'm still a novice in the diesel world (never owned one). I'm curious if this would be a good buy and I realize that is a completely subjective question.
This would be a second/hobby vehicle and I would pay cash (but not the asking price).
So, what I ask is this: If I take the time to visit the dealer and walk/test drive the truck, what should I look for / ask the dealer about the mechanical condition?
Thanks for your advice!
Sasmaster6000 is offline
post #2 of 4 Old 12-17-2013, 05:38 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
honestly. A 6.0 isnt a newbie diesel owners truck. Best bet for you is to try and connect with a local knowledgable 6.0 guy and have him with you
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #3 of 4 Old 12-17-2013, 05:49 PM
KS_
Quoted: 22 Post(s)
Your best bet if youve never owned a diesel is to go for the 7.3. You dont have to do a thing to it to make it last. Plus youll have the two body styles to choose from. Especially if you plan on doing a lot of hauling. If youre for play, guessing thats what you mean, then the 6.0 is your deal. But im a 7.3 guy and idk if your up for putting out the money for a 6.4 because ive heard thats a fun play vehicle too
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #4 of 4 Old 12-18-2013, 09:50 AM Thread Starter
Thanks for the replies!
If I do end up looking at this truck at the dealer, do you have any suggestions as to what I should look for? For instance, it's freezing outside. At cold startup the truck will smoke but at which point should I be concerned that the smoke is actually due to a mechanical issue (ie injector or whatever)??
I just want to make a smart, informed decision whether I buy the truck or not.
