Brake and Power Steering Problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-10-2013, 06:21 AM Thread Starter
Question Brake and Power Steering Problem
I have a 2005 Ford F250 6.0 Powerstroke TurboDiesel truck. This morning it was cold (20 degrees) and the truck started fine. I let it idle for a minute, then stepped on the brake and put it in reverse. I heard a small pop, and the brake pedal went down and got hard. The power steering also stopped working. I know that the systems are tied together on the diesel motor and it has the hydroboost. I checked the belt, and it is intact and turning properly. There is no fluid leaking under the truck. The power steering pump has been working fine, not making any noises, and I am wondering if it was just the temp, or if I broke something on the truck. Please help!
Ag Advisor is offline
post #2 of 5 Old 12-10-2013, 09:41 AM Thread Starter
Is this going to be a power steering pump problem or is there something else I should look for?
post #3 of 5 Old 12-10-2013, 11:32 AM Thread Starter
ok, after 15 minutes of warming up and above freezing temps, the steering and brakes are working again. Any ideas of what may have caused this so it dosnt happen again in the morning??
post #4 of 5 Old 01-13-2014, 11:36 AM
away's Avatar
Subscribing
2000 Ford Excursion
2001 F-250 Crew Cab Short Wheel Base
Pulling Trucks for
Drag Racing
1978 mustang II 363 CI SBF
1972 Maverick 532 CI BBF
away is offline
post #5 of 5 Old 01-13-2014, 12:17 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
when's the last time you flushed the system? could be water/moisture...or seal in the break part of it is going and just did'nt like the cold.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
