crankcase vent
does taking the crankcase vent out of the turbo system really help? i looked at the tag on the drivers door ,it said 1/99..is that the build date? and if it is what turbo does my truck have. i understand there are 2 different ones...how do i do the foil delet mod? i love the whistle
![]() FOIL DELETE AS far as the turbo, they switched over in 99, I think around march, so there is a good chance you have the older turbo. If I remember correctly, it is basicly the same wheel as the wicked wheel, but I could be wrong. |
If you the early turbo it is smaller in physical size, also you can tell whera the intake y-pipe joins the manifolds they are approximatly 2in in dia. the later one is 3 in.
Taking the crankcase vrnt out removes the oil from air intake, you won't get the oily residue at boots |
turbo size
my turbo inlet are 3 inch so is this the desired turbo?
if It is 3 in where the y-pipe meets the intake. Where the y-pipe meets the intercooler pipes is 3 in on both. I'll try to take pictures of the smaller one tonight.
which on eis better the smaller one or the big one?
the larger one!!!
You know what they say about everything
BIGGER IS BETTER |
thats what i thought but not shure, i just read how to shim my fuel regulator, is this safe to do with no guages,and the programmer
