Cab Light Plug Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-05-2013, 12:03 PM Thread Starter
7.3caseih's Avatar
Hey guys.
I picked up a set of OEM cab lights a while ago. I originally bought them for a 2001 super duty (2WD) and the plugs were the same, but I sold that truck and bought a 2000 (4x4) and the male end of the plug on the cab lights does not match the female end on my truck. I have attached a picture to show how the male end is longer then the female. How should I go about wiring my cab lights? I have some time off and would like to install them sometime soon. Thanks in advance for any help.
7.3caseih is offline
The Following User Says Thank You to 7.3caseih For This Useful Post:
Diesel Addict (12-05-2013)
post #2 of 3 Old 12-05-2013, 12:54 PM
Diesel Addict's Avatar
Is there anything currently plugged into the truck harness? If not you can take the wiring from the harness that has power for the lights and cut it and cut the plug off the cab light harness and butt connector or solder the two together. Or try to find a similar one in a salvage yard and either take the harness or plug and use it on yours. If there is something already plugged into the truck harness find the wire again that has power when the park lights are on and tap into it for power.
2006 F-350 CCLB
6-Speed Manual
6" Fabtech Lift, looking to go a few inches shorter and higher quality
35" Toyo Open Country MT's
AFE stage 2
MBRP 4" turbo back straight pipe
SCT Livewire tunes by Eric
Studded and deleted
The right to keep and bear arms SHALL NOT BE INFRINGED!
Diesel Addict is offline
post #3 of 3 Old 12-06-2013, 07:17 AM Thread Starter
7.3caseih's Avatar
Thanks for the reply. No there is nothing plugged into the truck harness. I think I will try butt connectors and see if I can get them to work. I'm fairly new to wiring so i'll do some research online and figure it out.
