1995 F350 coolant choices - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-04-2013, 07:46 AM Thread Starter
flj
I have very recently purchased my first diesel. It is a 1995 F350 crew cab 4x4 automatic.
I have been doing various maintenance items on the vehicle and have come to the coolant.
Reading on-line, there appears to be issues with corrosion in the engine caused by "cavitation" which typically has been remedied by using a coolant additive.
I have also read that there is a new extended life coolant which does not require the additive.
I am a chemist by profession and am very interested in the chemistry associate with these coolants.
It seems that the key component in the additive is nitrate ion which needs to be tested for on a regular basis.
For the extended life cool the key component is Potassium 2-ethylhexanoate (see CHEVRON DELO EXTENDED LIFE COOLANT/ANTIFREEZE PG msds)
https://cglapps.chevron.com/msdspds/...&docFormat=PDF
I have also read on-line that you cannot use the GM Dexcool coolant in these diesel engines. However, if you look at the msds sheet for Dexcool (see DEX-COOLŽ Extended Life Antifreeze/Coolant msds)
https://media.toro.com/Documents/safety/104-8606.pdf
it also includes only Potassium 2-ethylhexanoate as the active ingredient. Dexcool also includes diethylene glycol but that chemical serves the same function as ethylene glycol which both Delo and Dexcool contain and would not affect corrosion.
My question is has anyone used Dexcool in their early 7.3 powerstroke engines since it is much more readily available than the Delo coolant?
Thanks.
flj is offline
post #2 of 6 Old 12-04-2013, 08:21 AM Thread Starter
flj
Thanks.
What about using this stuff?
Zerex G-05
Zerex 1 Gallon G-05 Antifreeze & Coolant - ZXG051
flj is offline
post #3 of 6 Old 12-04-2013, 09:43 AM Thread Starter
flj
Thanks.
I just found Delo pre-mixed coolant available locally for $10.86 per gallon. The concentrate is $19.33 per gallon so I do not see much benefit in going that way.
Hopefully this will work in my truck and I will never have to change the coolant again.
flj is offline
post #4 of 6 Old 12-04-2013, 11:21 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Im about to do a flush on my 95 and im going to use this Buy Peak Fleet Charge Antifreeze/Coolant (125 oz.) FCA0B3 at Advance Auto Parts
Its precharged with SCAs which is the additive needed to prevent rust and cavitation.
You need to get a concentrate not premixed because you are unable to remove 100% of all the coolant trapped in the engines various places so in order to maintain a 50/50 mix you fix with half with concentrate then top off with distilled water and that will yield as close to 50/50 as you can realistically get
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 6 Old 12-05-2013, 07:55 AM Thread Starter
flj
Thanks for the info.
If you go to the Peak web site PEAK COMMERCIAL & INDUSTRIAL | FLEET CHARGE | HEAVY DUTY COOLANT/ANTIFREEZE | FAQS
They make the following statements:
Q: Is FLEET CHARGEŽ an "extended life" coolant?
A: The term "long life" usually is associated with coolants that contain carboxylic acid inhibitors. Therefore, we have described FLEET CHARGEŽ as a Fill-For-Life technology.
Q: What is meant by the term Fill-For-Life technology?
A: The Fill-for-Life alternative provides for easy, low cost monitoring of the coolant inhibitor and freeze protection levels. Fill-For-Life is an extended service maintenance program developed by FLEET CHARGEŽ and Penray researchers. It is very simple. Users simply install a Penray Need-Release filter on an engine coolant system (up to 30 gallons). Every 18 months the filter is replaced. This practice eliminates scheduled coolant changes.
From what I read, you must install and use a special filter to be able to use this coolant. Need ReleaseŽ Extended Life Cooling System Filters | PenrayPenray
If you read the MSDS sheet for the Fleet Charge Coolant
http://images.peakauto.com/Fleet%20C...v%20052013.pdf
you see that it contains no additives at all. It is just ethylene glycol and diethylene glycol to prevent freezing/boiling and a small amount of a chemical to make it taste bitter so you don't drink it and get poisoned. All of the SCA comes from the filters that you install.
I still like the idea of the Delo ELC which seems to be more or less fill and forget. Diesel Coolant, Delo Prediluted & Extended Life Antifreeze - Delo - (United States)
Just check the freeze point twice per year.
flj is offline
post #6 of 6 Old 12-05-2013, 08:09 AM
Chapter Director
Quoted: 5 Post(s)
What you may or may not know is you cant use any ELC coolants in a truck made before 2/2/99 because they werent designed for ELCs. They will eat away at the injector cups and seals in the water pump because they arent compatible. That being said there are a few guys that do run it but i dont think theres any conclusive results from that.
The only coolant approved for our trucks is the Ethylene-glycol coolant and then to prevent rust and corrosion you need to add SCA additive(which fleet charge comes with already added) then maintain SCA levels every year or 15,000 miles after.
Im no chemist by trade like you but im personally going to go with what has been done since these trucks were rolled out since it seems to work
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
