whats better in mud....
1996 extended cab 4x4 powerstroke with 35inch boggers and rear locker. Or 2004 chevy duramax 4x4 extended cab longbed with 35 boggers and factory rear locker? I own both and would like to no what to put some offroad money into.
solid axle wins my vote
id say mud the 96...the 04 is newer and wouldnt wanna take it into the mud. the 96 is all leaf suspension so its gonna stay planted to the ground
Don't let the "newness" frighten you,...the only reason I wouldn't use the Chevy is because of the front end weakness.
My truck was 6 days old when I cut the fenders off, and when it was 26 days old,...it took it's first "mud bath"... ![]() ![]() ![]() ![]()
sweet. what would have better traction? Would the ford just sink? way more than the chevy?
both are diesel's so the weight won't be too different at all.
traction,...another thing that will be the same. Like I said the biggest (huge) difference is the solid axle in the Ford,....alot stronger than the Chevy.....you don't see many mud rigs changing to IFS do ya,...they all do SAS's for a reason. |
Look around, Serious offroaders always use Jeep, Toyota and Ford. It's a fact . Very few use Chevy, except for Chevy engines in Jeeps. GM axles stink.
And the front suspension of coarse has already been addressed. |
Both trucks are boat anchors they wiegh so much that they sink in the mud.
Mavsps you never did say if the 96 was an F250 or F350.The reason I say this is the 250 is a TTB axle, not a true solid axle. Even still i would put the money in the ford. the TTB is still stronger than the Chevy front end.
Well if it was only a one time deal i would say the duramax because the IFS has more clearance and the duramax will most likely make more wheel speed than your 96. If i was using it for a constant mudder I would say the 96 because it will take a lickin and keep on tickin also you can build the suspension and axles up way easier than you ever would the chebby, the IFS is for a high way mochine
