NEED HELP QUICK!! - Ford Powerstroke Diesel Forum
Old 08-22-2008, 01:09 PM
NEED HELP QUICK!!
i have an 2001 powerstroke and coolant has been leaking out of to be what looks like the pump for a long time.it looks to be coming out right behund the pulley. it started out dripping and now after drivng it for a while it is pouring out. is it the hose or is it the pump? does the pump have a seal behind it that culd be replaced?thanks guys
Old 08-22-2008, 01:21 PM
duct tape & zip ties
Most likely you need a new waterpump. Let the engine cool down and inspect the hoses and pump. But I would be prepared to replace that pump.
Old 08-22-2008, 01:23 PM
it is still pumping fine cause the engine hasnt gone up in temp at all even sitting on a hot day! so you dont think the seal would work?
Old 08-22-2008, 01:37 PM
It depends on where it is actually leaking at.
