power steering fluid - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-22-2008, 10:59 AM Thread Starter
Send a message via AIM to kx592
I think its time for new fluid..how do i drain the current stuff and what should i refill with and how much? 97-7.3
1997 7.3 extended cab 8ft.
4" straight piped
DIY intake- 6637 filter
178K on the dash
Boost, PYRO, Trans temp gauges (auto meter)
33" nittos on stock height
kx592 is offline
post #2 of 4 Old 08-22-2008, 11:03 AM
cblackb's Avatar
Well there's two ways. You can either unhook the hose furthest to the bottom (the one that is hardest to get to) and drain it there. Or what I did. I just used a hand vaccum pump and pumped the fluid out of the reservior and then filled it back up. I then started it and turned the wheels several times and pumped it back out and refilled it again. After three times I was pumping out clean fluid and was satisfied I'd gotten 95% of the old stuff out. I used about 1.5 quarts of fluid.
2000 F-250 XLT PSD Auto Super Cab SB 4x4
Magnaflow 4" straight-piped into duals
Eclipse Sport Trucks Body and Interior Conversion
Tinted Glass
Zoodad Mod
Diablosport Chip (don't know HP)
Foil Delete Mod
DIY/6637 Intake Mod
Oilguard Bypass Oil Filtration System
CCV Mod
HPX Mod
Mag-Hytec Everything
BTS Valve Body
Cobra 29 LTD CB Radio
IAH Delete
cblackb is offline
post #3 of 4 Old 08-22-2008, 11:10 AM Thread Starter
there are no drain bolt,plugs?
4" straight piped
178K on the dash
kx592 is offline
post #4 of 4 Old 08-22-2008, 11:19 AM
cblackb's Avatar
Well I have a 2000 so I'm not positive we have the same pump but we probably do and no, mine has no drain, you have to pull the line or pump the old stuff out.
Tinted Glass
Zoodad Mod
Foil Delete Mod
DIY/6637 Intake Mod
CCV Mod
HPX Mod
BTS Valve Body
IAH Delete
cblackb is offline
