Carrier bearing play..... - Ford Powerstroke Diesel Forum
Old 08-17-2008, 03:10 PM
Real Men Love Jesus! <><
I looked under my truck and saw my carrier bearing has some play in it. I can pick up the driveshaft around the bearing area, and can push it up about 1/2" or better. I am thinking this is bad. I have never any experience with these before. The rubber section around the bearing is loose inside the "U" shaped peice. Is this good or bad?
Old 08-17-2008, 03:12 PM
Almostdunfukinwidit
The is supposed to be a little bit of play in them
Old 08-17-2008, 03:13 PM
1/2" up and down?
Old 08-17-2008, 03:14 PM
Almostdunfukinwidit
Im not sure if thats too much or not without crawling under it myself.
Old 08-17-2008, 03:16 PM
Ok, I might have ask some other PSD owners at the store next time I am there and ask to see theirs. haha....
Old 08-17-2008, 03:17 PM
ADMIN AND TECH
i think its normal
Old 08-17-2008, 03:20 PM
I'd say a half inch is too much.... you should be able to move it only slightly.
I just changed mine out, same year as yours. Not a bad job. If you're lifted, might as well shim it at the same time.
Old 08-17-2008, 03:44 PM
Not lifted at all. But, I will leave it alone and monitor it since the guru has spoken. hehe.
Old 08-17-2008, 04:00 PM
Did he tell you not to worry a few days ago when you asked
Old 08-17-2008, 04:08 PM
well, he said it wouldnt be causing my vibration. I didnt specifically ask if it was bad or not. I didnt mention the play it had.
