06 F250 6.0L Fuel leak...Help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-21-2013, 04:12 PM Thread Starter
Have an 06 6.0L. Fuel smell is in the cab. I have looked at the fuel filter up top along with regulator. no keaks found there or at the turbo. No diesel in the coolant, heads are not cracked. Drops only a few drops of diesel over night. This started after I ran it pretty hard just blowing the smoke out. I pulled the EGR, its clean and functioning. I looked underneath. It appears the fuel is leaking from underneath drivers side. Any suggestions
Jumbo1190 is offline
post #2 of 3 Old 11-21-2013, 06:51 PM
Quoted: 769 Post(s)
Fuel line/hose frame rail??
Corey@CNCFAB is offline
post #3 of 3 Old 11-23-2013, 12:18 AM Thread Starter
OK thanks. I'm going to take it and put it on a lift and look. I just hope she will make it till I can get it in.
Thanks for the suggestion
