02' to 05' & newer conversion - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-14-2008, 06:05 PM Thread Starter
scagmanf350's Avatar
I am in need of replacing my entire front end (ball joints, sway bar, etc.) Currently I have a 2002 4x4 ex. cab long bed 7.3 liter diesel. I was wondering if I could convert my existing front end to the newer coil front ends found on the 05 & newer trucks (I want to keep my 4 wheel drive no 2wd conversion tips). This would improve the ride and turning radius of the truck which are two things I need desperately. This is a work truck not a super mod or off road vehicle. I just want to know if the front ends from the 05' and newer trucks could be used on my 2002. Also if anyone has any idea what this might cost that would be helpful.
1999 Ford F350 Crew Cab Dually 4WD 7.3 Powerstroke
scagmanf350 is offline
post #2 of 5 Old 08-14-2008, 11:08 PM Thread Starter
***bump***
post #3 of 5 Old 08-15-2008, 01:08 AM
jjames25's Avatar
it would probably be easier to get a 4link conversion from a manufacturer than to switch . You would need a full donor truck and you'd have to gouge off you existing leaf mounts and weld in radius arm mounts from the donor plus fit the spring pockets from the donor truck and the front diff . Lots of fitting and welding and drilling plus cost of 05-07 parts you could buy a fabtech 4 link and coilovers for around the same price or less
2oo6 f350
6" procomp lift, Dual steering stabilizer
predator zoodad
accufab elbow, duals no cat or muffler
airaid intake, 17" motometals 35" toyo m/t's
alpine iva w205 deck, SCT xcal2
carriage works billet grill ,rodadeaco positive air shutdown
300 amp lincoln welder in the back
harley headlights in the box
fox 2.0 piggyback shocks in the box
2003 Dodge 3500 5.9 cummins
AEM intake, dual mitre cut stacks, Edge EZ , Smarty programmer, Webasto heater
jjames25 is offline
post #4 of 5 Old 08-15-2008, 09:30 PM Thread Starter
thanks I'll look into that
post #5 of 5 Old 08-22-2008, 02:02 PM
I'm doing this conversion on my 2005 Excursion. You will not get the better turning radius unless you swap to the 2005+ axles, plus stock Ford suspension parts will be easier to find (and cheaper) if you break stuff. Should be about $2,000 for a low mile front and rear axle, plus about $500 for a front frame cut to get the brackets you need.
Totenkopf is offline
