injectors???
allright i was borred today so i was lookin at injectors and videos of diesels on youtube. and i havea few questions.
whats the difference between stock and stage 1 injectors? how much of a increase in power will i get with stage 1 injectors ? what about stage 2? will it decrease my mpg ? by how much? i saw a cummins with stage 5 injectors on youtube tryin to black smoke ? and just as much as comes out of my stock powestroke injectors was commin out of his? whas the main advantage to upgrading injectors? thanks for any help!!! |
on an OBS injectors make a huge difference.
my truck has stage 1 injectors from Rosewood, they use the stock nozzles but use a machined intensifier piston so they flow about 160cc, the stock ones flow about 90cc. if anything my mileage went up with the injectors, i don't have to have my foot in it all the time. |
allright thanks! how much you pay for them? and how hard is it to install them?
i did mine over a year ago but you can get them at DIY-injectors.com
i think the owner is a member here actually they were really cheap considering the power difference. pretty sure they were under $500 including the pistons they weren't that hard to do, i do recommend getting the pre machined intesifier pistons so you can do the whole job in one day |
Outlaw Diesel Performance :: Home This sight is by far, the best price on the net. "bdpp" I've spent a lot of time messing around with your idea. If you don't want to get in to a lot of money, go with the stage one straight shot injector. If you go to the stage 2 you will have to up grade your turbo,HPOP etc,etc. you should have enough oil pressure so you don't have to go to the BIG OIL - Pulse line. but good luck hope every thing turns out.
